Which Replacement CV Axle worked best?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by danbow, Jan 10, 2017.
Which type of CV axle did you use?
  1. Used
    0 vote(s)
    0.0%
  2. Aftermarket
    3 vote(s)
    60.0%
  3. Reman
    2 vote(s)
    40.0%
  1. Jan 10, 2017 at 2:49 PM
    danbow
    danbow [OP] Member
    Daniel
    Texas
    18 F150 Crew 4x4
    I replaced a CV axle last year with an aftermarket one and the boots didn't look quite right, so I was skeptical of the quality.... I may be replacing it with another and keeping it as a trail spare. I had a used one come in, but the threads were smashed on the end from when it was removed off of the donor truck.
    Just wondering what kind of luck yall were having with the different types available.
    New OEM is not an option due to cost at this point.
  2. Jan 10, 2017 at 2:51 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    CVJ remans have done me right, need an OEM core or core charge
  3. Jan 10, 2017 at 2:52 PM
    danbow
    danbow [OP] Member
    Daniel
    Texas
    18 F150 Crew 4x4
    I still have the non-usable used axle, figure I could use that as a core if needed. What was cost on that?
  4. Jan 10, 2017 at 3:01 PM
    hoarder23
    Shay
    NJ
    Scratches
    I forget as it's been a few years but not significantly more than the chinese ones from the auto chains
  5. Jan 10, 2017 at 3:03 PM
    danbow
    danbow [OP] Member
    Daniel
    Texas
    18 F150 Crew 4x4
    Ok thanks, I just emailed them for a quote.
