Which rims look better on my first gen?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoboy1, Oct 8, 2021.
  1. Oct 8, 2021 at 11:47 AM
    Tacoboy1
    Tacoboy1 [OP] Well-Known Member
    Nathan
    Southern California
    2000 Tacoma 92k miles
    Hello everyone, I have a 2000 Tacoma and I want to get some new wheels for it, I still have the stock wheels with the ugly hubcaps which are faded from the sun. I was looking at 2 particular wheels that I like, I feel like chrome looks clean since I have a white truck, but I also like the aggressive look of black so I’m not too sure what to get, let me know what you guys think. Thanks:thumbsup:
  2. Oct 8, 2021 at 11:57 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Op it is what you like!!
    Myself I would go Steel Wheels Painted Hot Pink!!
    Not for everyone but my Choice .
    It does not matter I have 5 gallons of the Color paint
    tarbal255, Tacoboy1[OP] and treyus30 like this.
  3. Oct 8, 2021 at 12:00 PM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    pro comps 51
    Tacoboy1[OP] and boston23 like this.
  4. Oct 8, 2021 at 12:25 PM
    notrouble
    notrouble Well-Known Member
    western Washington
    2004 single cab 2wd
    I would want something with a little more stock offset (ET +34 to +38) so they stay under the fenders. If you push the tires out too much rubbing becomes more likely. Personally, I prefer aluminum wheels, in colors or polished and clear coated. There seems to be a problem with so many newer chrome parts rusting. Have you looked here https://www.tirerack.com/wheels/res...toModel=Tacoma+2wd&autoYear=2000&autoModClar=
    I'm running the Sport Edition A8-2 on my 2004 5 lug. I chose P235/60R16 tires, a perfect match to the height of my original 15 inch tires. To keep your stock height, and the speedometer right, you would likely want something like P205/60R16 or P225/55R16.
    Tacoboy1[OP] likes this.
  5. Oct 8, 2021 at 2:00 PM
    1997tacomav6
    Denver
    I was thinking about the 16” pro version myself , but not sure if tundra brakes would fit
  6. Oct 8, 2021 at 2:48 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    He's got a 5 lug.
    1997tacomav6[QUOTED] likes this.
  7. Oct 8, 2021 at 4:11 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Out of those two? the Black, 100%
    But I generally hate anything chrome, so I'm biased.
    But as @Taco critter said, those really aren't all that different from your stock ones hidden under your hubcaps.
    Pull your wheels off, get a couple decks of playing cards (to mask the tire) and go to town with a rattle can.
  8. Oct 8, 2021 at 5:26 PM
    Bivouac
    I must be getting Frugal with old age.
    Young and dumb $$$$$ so much show and no Go.
    I really think it is a stage if your mechanically inclined we all go through.
    Now my Stock 15" wheels are just fine much more critical things to spend money on.
    Bubba’sTaco and Taco critter like this.
  9. Oct 8, 2021 at 5:28 PM
    Mabears80
    Mabears80 Member
    2000 black 2WD Extra Cab
    I have the black steel rims for my truck so I am a bit biased.
  10. Oct 8, 2021 at 5:51 PM
    04taccoo
    04taccoo Well-Known Member
    Cyrus
    San Diego
    2004 Tacoma prerunner 4x4 double cab
    4x4 conversion
    I run the pro comps
  11. Oct 8, 2021 at 6:38 PM
    AmherstAndy
    AmherstAndy Well-Known Member
    Andy
    Masshole
    2003 2.7L 5 speed, 4x4 J shift, Xtracab
    Freshly painted oem steelies with center caps?
    Taco critter likes this.
  12. Oct 8, 2021 at 7:16 PM
    skycamper
    skycamper Well-Known Member
    Abraham
    2001 Tacoma 4x4 2.7L Ext Cab
    3" Lift w/ 5100's and EMU 882 springs , General Leaf Spring and AAL in rear with 5100. Diff drop, carrier drop, 3 degee axle shims. Trail Gear Tube Bumper. Tundra brake mod.
    I like this one! But maybe needs to be a 4x4.
  13. Oct 9, 2021 at 11:02 PM
    Tacoboy1
    Nathan
    Southern California
    This truck is clean!
    04taccoo[QUOTED] likes this.
  14. Oct 9, 2021 at 11:04 PM
    Tacoboy1
    Nathan
    Southern California
    I was thinking of doing this but then I ran into a guy at the oc yoga nights in orange and I saw a bunch of 5 lug first gens but there was 1 in particular and it was so clean! Had a 3 inch lift, 30x9.5 tires with 15x8 procomp 51s and I loved it, I’m for sure getting the procomps!
  15. Oct 9, 2021 at 11:06 PM
    Tacoboy1
    Nathan
    Southern California
    That’s one concern about the chrome, I personally like the chrome because it looks very clean but the pro comps are a little more aggressive and I like that.
  16. Oct 9, 2021 at 11:08 PM
    Tacoboy1
    Nathan
    Southern California
    What size tires are you running?
    04taccoo likes this.
  17. Oct 9, 2021 at 11:34 PM
    Nicklovin
    Nicklovin Mall Crawlin Through Life
    Nick
    Huntington Beach, CA
    00 The Tunda - 0̶4̶ P̶r̶e̶r̶u̶n̶n̶e̶r̶ - 0̶1̶ O̶v̶e̶r̶l̶a̶n̶d̶e̶r̶ - 07 FJ Mall Crawler Xtrme
    Tacoless
    EF100F1D-5BF8-42A6-84F9-1E77C5C127C2.jpg I run newer 4runner wheels, I like the shiny :D
  18. Oct 10, 2021 at 1:24 PM
    04taccoo
    Cyrus
    San Diego
    4x4 conversion
    Thx man. I’m on 285/70/17
    Tacoboy1[QUOTED][OP] likes this.
  19. Oct 11, 2021 at 4:19 PM
    Johnny_Mac
    Johnny_Mac Member
    Johnny
    SW Washington
    2003 Prerunner DoubleCab
    Cool Sasquatch sticker
    I like the black Pro-Comps much better. Plus the chrome never seems to go too long before it's rusting or bubbling/peeling. If the black wheels start to rust, you can touch them up yourself much easier.
  20. Oct 11, 2021 at 10:02 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    3D486B2F-747F-4A6C-8C4A-BD115ECCDA1B.jpg I dig me some D window steelies
    Johnny_Mac, Tacoboy1[OP] and 04taccoo like this.
