Which setting do you use on your dSLR?
Discussion in 'Photography' started by rb11701, Sep 16, 2010.
  1. Sep 16, 2010 at 6:21 AM
    rb11701
    rb11701 [OP] Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    Do you guys shoot in Auto? Use shutter/aperture priority? Manual?
    If manual, how do you guys go about getting the right settings? Do you just eye it? Take a few test shots? Do you have you own "sweet spots" for certain applications (like a certain shutter speed at a certain f stop for say sunsets etc) that you start from and go from there?
    I shoot a lot of pics, but sometimes just can't get what I am looking for. so i am looking for few tips on how to better use the shutter speed/apereture mix. Like why would I use a low shutter speed/wide f stop over a fast shutter/small f stop? Stuff like that.
    Or point me to a book/forum that I can always fall back on? Would a class be my best bet?
    Thanks!
  2. Sep 16, 2010 at 9:24 AM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    Use auto if you can't decide on the settings...
    But for real. Mess with the settings until you get the image you want. I cant tell you what exposure/aperture to set yours at because we have different cameras, settings, subjects, eyes, lenses, etc.
  3. Sep 16, 2010 at 9:28 AM
    Chachie
    Chachie Well-Known Member
    Justin
    Nor Cal
    '06 TRD OR, 4x4, Auto, 6" Fabtech, 35's
    Locker mod, Anytime fog mod, always 400w mod.
    I use P on my XTi. It will allow me to set the shutter/aperature to what i want. Its a little more control than auto.
  4. Sep 16, 2010 at 9:31 AM
    JDMcompliant
    JDMcompliant Professional Amateur
    Joe
    San Diego
    2010 Tacoma 4x4 4.0L V6
    I shoot in Av most of the time, as I always know what my Aperture needs to be, but not always how long it should be exposed. I switch to Tv when doing night shots, or long exposures under 30 seconds. When I do portraits with external flashes, I shoot exclusively in Manual, as the auto modes cannot accurately expose photographs with external flashes.
  5. Sep 16, 2010 at 9:31 AM
    widget
    widget Well-Known Member
    TN
    2010 Prerunner double cab
    The higher the f-stop, the more "in focus and background" you're going to have in your pic. Think of it as making a small hole (sm. f/stop) versus a big hole (higher f/stop). Shutter speed is going to capture whatever based on subject/action and available light (f/stop lets that happen), flash, etc.. In "auto" you're going to get a "smart picture" which is the best the camera knows how to do for you. But in a manual setting, you can "trick" the lens as at it will only do what you set it to do/see and you can get some "special" of different effects if that's what you hope to do.
    As someone mentioned, try a few, number and write down your shutter and f/stop on each pic so that way you'll know what you did that gave you that result.
  6. Sep 16, 2010 at 9:36 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Manual is all it shoot on really there in no set shutter speed and aperture the available light will always be different.
    Depending on the camera you have using the exposure bar in your view finder in a good place to start then you can fine tune your exposure for the shot you want.
    Really it's trail and error when you first start shooting in Manual but once you get use to it it's second nature.
    And another thing if your not shooting in Raw start.
  7. Sep 16, 2010 at 9:49 AM
    futuretacoowner
    futuretacoowner Well-Known Member
    Andrew
    Canada
    02 2.7L xtra cab
    right now i am set on aperature priority sometimes i shoot in manuel and some other times in shudder priority. Now to thread jack for a second, can anyone tell me why my shudder stays open too long when using the built in flash.
  8. Sep 16, 2010 at 9:54 AM
    JDMcompliant
    Joe
    San Diego
    you probably have it in Av or Tv. P mode will keep your shutter speed down when dealing with built in flash.
  9. Sep 16, 2010 at 3:25 PM
    senna
    senna Well-Known Member
    San Jose CA.
    09 DBL CAB TRD-OR OME shocks 885 and AAL
    Maybe it is cold and shuddering so bad the shutter can't close. :rolleyes:
  10. Sep 16, 2010 at 3:29 PM
    futuretacoowner
    Andrew
    Canada
    02 2.7L xtra cab
    its starting to get chilly here but not that cold!!!:)
  11. Sep 16, 2010 at 3:40 PM
    MaidenFan
    MaidenFan Well-Known Member
    Everett, WA
    2008 AC TRD Sport Indigo Ink
    Mods: Missing right rear mud flap
    Try this site out to start with. A lot of good stuff in there.
    http://photography-on-the.net/forum/
    I agree that the more I shoot, the more I keep it on Aperture Priority. I want to control the aperture more than anything else, shutter is easy, look what the camera wants to set it and if its too slow, change the aperture or pump up the ISO some. Don't be afraid of pumping your ISO up, you can get some really cool shots that way.
  12. Sep 17, 2010 at 8:52 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    i shoot 100% raw in manual mode...
    i been doing this a while, so my settings kinda just fall into place... i typically look at my subject surroundings, and start at a setting that i estimate and adjust from there... on average, i adjust maybe 2 or 3 stops from my starting point, so i have been fortunate...
  13. Sep 18, 2010 at 4:48 AM
    rb11701
    Rob
    That is my problem, I just need to shoot more. I have a hard time figuring out where I should start. Always end up with either over or under exposed shots.
  14. Sep 18, 2010 at 6:28 PM
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
    Good. Now find a perfect medium ;)
  15. Sep 18, 2010 at 6:59 PM
    MaidenFan
    Everett, WA
    If you feel like your settings are close to what you want but your still getting over/underexposed shots, you can move your exposure compensation a bit too. That helps me a lot when I know the Seattle sky will make things a darker than I like
  16. Sep 18, 2010 at 7:30 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    A great book and well worth the $15.00 to $20.00 is Understanding Exposure by Bryan Peterson.
    As far as settings.
    I use Aperture Priority 95% of the time. I use manual if I feel it's needed but AP works well most of the time.
  17. Sep 18, 2010 at 9:48 PM
    ocabj
    ocabj Well-Known Member
    Riverside, CA
    2010 Pyrite Mica Tacoma Standard Cab
    Aperture Priority ('AV' in the Canon world) when shooting natural light.
    If I'm shooting outdoors with a Speedlite on the shoe for fill flash, I'll shoot AV if the light is changing constantly (clouds) and about -1 FEC. If it's constant light conditions (bright and sunny), then I'll shoot manual if I need it.
    Sample of AV with Speedlite on the hot shoe for fill:
    If I'm shooting with off-camera lighting (strobes and/or small flash), then I usual manual. I set exposure for the background and adjust my strobes in order to light the subject according to the settings I have to expose the background the way I want it.
    Sample of manual with off-camera strobe (set exposure to normally expose background, subject lit accordingly):
    Sample of manual with off-camera strobe (set exposure to under expose background, subject lit for normal exposure):
  18. Sep 23, 2010 at 1:41 PM
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    I shoot full time in Manual. For recommendations on settings, I would focus mainly on F-Stop, Shutter Speed, and ISO.
    A basic overview (and correct me on anything that I am wrong about):
    F-stop controls the size of the hole the the camera is taking in light, the the larger the number, the smaller the hole. The larger the f-stop the darker the picture will be. Also the larger the F-stop the deeper the depth of field which is how much of the picture is in focus. The shutter speed is how long the shutter stays open and takes in light. The longer the shutter speed stays open, the brighter the picture will be, but the down side is if the camera or the subject moves then the picture will be blurry. The ISO is the light intensity. The higher the ISO the brighter the picture will be, but the more noise will be in the picture.
    I usually set the ISO to as low as I can to keep noise at a minimum and still get the shutter speed decently fast to freeze motion, and a large enough F-Stop (small aperture) to get a deep depth of field.
    If I'm shooting sports in sunny conditions, I would set the Shutter Speed to around 320 or 400 and the f-stop to around 3.5 or 4.0. Which leaves me with enough light to keep the ISO low. But I've been told by fellow photographers to shoot with an even faster shutter speed and compensate with a higher ISO to freeze even the motion blur of say a football in the air.
    For portraits, it would depend on if I want the background included in the picture sharply, or blurred out. If I wanted the background included, I would set the f-stop to around 8.0, a low ISO and whatever shutter speed to get an even exposure, but no slower then 60 in case the subject moves slightly. If the picture is too dark, then I would increase the ISO.
    If I want the background blurred out then I would bring the f-stop down to 2.8 or 3.2 and do the same as above with ISO and shutter speed.
    For landscapes I would set the largest f-stop reasonable to keep the ISO low and the shutter speed would depend on if the scene was windy or not. If it was windy trees or other things might sway back and forth so your shutter speed would need to be faster so it freezes the motion. If all is quiet then the shutter speed can be set slower and a larger f-stop.
    If I'm taking pictures of something macro, I would set the f-stop to the smallest number for a shallow depth of field, keep the ISO low, and again keep the shutter speed faster then 60, unless there is a tripod involved.
    For flash, I think it is a personal preference. I use it sparingly because the only one I have is the built in flash, which isn't very flexible in terms of functions. Just make sure the picture isn't to washed out by the flash if you use it.
  19. Sep 23, 2010 at 1:46 PM
    Drunknsloth
    Retribution
    South West
    The meter on the camera is usually pretty good at keeping the exposure even, to get it even closer to balance get a grey card.
  20. Sep 23, 2010 at 1:50 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    im sorry did you say something?
