Which setup???
Discussion in 'Suspension' started by Gavinfritz101, Aug 21, 2011.
  1. Aug 21, 2011 at 11:06 AM
    Gavinfritz101
    Gavinfritz101 [OP] THE Gavin Fritz.
    Gavin
    Temple, Tx
    01 SR5 4x4 Gold
    Blacked out emblems, grill guard, Wade wind deflectors, White led dome light, Camo Steering wheel cover.
    Which setup is best? Bilstein 5100s all around with front at 2.5 with a rear aal, or 5100s in front with eibach coils and a rear aal? Which looks best, rides best, or anything. Thanks
  2. Aug 21, 2011 at 11:17 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    The best setup would be the 5100s set at 0 with eibach coils up front and the AAL and 5100s in the rear. The eibach coils will most likely give you a little over 3" of lift until they settle and may cause your cv boots to need to be replaced.
  3. Aug 21, 2011 at 11:42 AM
    Gavinfritz101
    Gavin
    Temple, Tx
    01 SR5 4x4 Gold
    How much are cv boots?
  4. Aug 21, 2011 at 3:44 PM
    Norton
    Norton Senior Member
    Monument, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C, OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; aFe POWER Magnum FLOW Pro DRY S Air Filter; NSB-AGM27F Battery w/Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; MetalMiller TRD Skid; jsi's Locker Anytime & ramonortiz55's Always on Power Outlet Relay Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades (RallyLights Harnesses, Osram 85/80W H4 & Flösser 90W H11 Bulbs); mattgecko's Underhood Lighting; ND4's Fog Light Anytime Mod; Interior & Reverse LEDs; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; 4Runner 4X4 & FJ Fog Light Switches; Husky Floor Liners; UltraGauge EM; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Toyota Bed Extender; Pop & Lock Power Tailgate Lock; ARE Z-Series Cap, SolarGard Tint; BlendMounted BEL Vector 995; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    Replacing the springs is usually the best option. Speaking of which, how far "gone" are your rear leafs? In many cases, an AAL only delays the inevitible leaf pack replacement. If yours are bad enough, the cheaper long-term solution MAY be to do that instead of an AAL.
  5. Aug 22, 2011 at 8:11 AM
    kmok
    Kyle
    Columbus, Ohio
    It's easier to replace the whole axle than the actual boot, but the boots aren't that expensive. Reman axles from Toyota are like $175 and reman axles from autozone are a little over $50 with a lifetime warranty so if you break an axle or rip a boot again you can get another one for free. I went the autozone reman axle route.
