which shocks
Discussion in 'Suspension' started by Eman5pt0, Nov 29, 2011.
  1. Nov 29, 2011 at 11:15 PM
    Eman5pt0
    Eman5pt0 [OP] Well-Known Member
    E
    NY
    so i did a bunch of research i read through at least 100 posts and still cant decide but im picking up a set of 885Xs and wondering what shock to go with 5100's or OME. I know people run both but figured id ask. any pro's or con's from running one or the other? DO they both give the same amount of lift?
    and if anyone can post pics of there ride with 885's with OMEs or 5100s that would be great
    also where can i buy a set of OME's i only see them paired with the springs
    thanks
    Eric
  2. Nov 29, 2011 at 11:17 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    Get the OME shocks.
    and go to wheelers offroad.
  3. Nov 29, 2011 at 11:19 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    How much lift are you looking to get?
    the shocks themselves do not give lift, the lift you'll be getting is from the 885's (Rated for 1.75" on 2nd gens)
    the 5100's give lift by changing where the coil perch sits on the shock, adding pre-load to the coil to give lift- but if you have a lift coil it's not really necessary
    usually people go with the OME shocks paired with the coils because the shocks are valved better for the coils
  4. Nov 29, 2011 at 11:49 PM
    Eman5pt0
    E
    NY
    i would like to go with as much a lift as i can with what im getting. from what i have read. the setup gives you 2 or 2.5in of lift. if i can get a full 3 id be happy. i also have UCA to go in with the lift
  5. Nov 30, 2011 at 12:54 AM
    Eman5pt0
    E
    NY
    one other question. will i need a 1/4in spacer for t he drivers side if i decide on 5100's ?
  6. Nov 30, 2011 at 3:11 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    OME is a good option........or look into toytec's 3" lifts. Basically uses an eibach coil with the 5100 and they have a pre assembled set ready to bolt in!
