which size aal with OME 881
Discussion in 'Suspension' started by medikirk, Aug 26, 2011.
  1. Aug 26, 2011 at 4:46 AM
    medikirk
    medikirk [OP] Active Member
    Caleb
    North Carolina
    02 SR5 2.7l 4x4
    3" lift Deck Plate Mod Dynomax Super Turbo Muffler
    do i need a 1.5 aal or will a 2 inch do. if 2 inch will is cause the rear to be too high pare with the 881's. i would like it level as possible. thanks
  2. Aug 26, 2011 at 5:15 AM
    JaSkynyrd
    JaSkynyrd Ron F. Swanson
    Chattanooga, TN
    2001 XtraCab 4x4 V6 SR5
    I've got 881s on the front and it lifted a little over 2 inches, if you lift the rear two inches you will just about keep your factory rake, I went with the 1.5 progressive aal, they are at my house but unistalled but I guarantee 1.5 will come alot closer to leveling you out than the 2 inch, you'll blow right past level and quite possibly rake it even more than stock.
    And by the way my photo below is not how it sits now so don't go by that.
  3. Aug 26, 2011 at 5:30 AM
    medikirk
    Caleb
    North Carolina
    02 SR5 2.7l 4x4
    ok thanks.
