which springs?? any ideas??
Discussion in 'Suspension' started by OU812, Jan 5, 2009.
  1. Jan 5, 2009 at 1:28 PM
    OU812
    OU812 [OP] ban the term murdered out
    danusa
    Kilroy was here
    13 DblCab LB 4X4
    Nothing yet, brand new!
    I'm a little torn on a decision I need to make. So I"m asking for some opinions.
    First off, I DID NOT have the rear spring TSB done. ( I was too late to the party:() I"m looking to get a mild lift on the back end but mainly help for towing/hauling. My choices are
    a: Deaver leaf pack
    b: OME Dakar leaf pack
    Who is running either of these and do you like them? Are they comfortable on the road as I'm mostly on the highway.
    Can you do a AAL later on if need be for either setup?
    I tow-- a lot! So hopefully either of these will hold up as a new addition on my ride.
  2. Jan 5, 2009 at 3:16 PM
    OU812
    danusa
    Kilroy was here
    13 DblCab LB 4X4
    What about shocks? Use the OME ones with these or Bilstein?
  3. Jan 5, 2009 at 3:56 PM
    sonjay
    sonjay Well-Known Member
    I also have the OME dakars with the OME shocks. Great ride on and off road, really sucks up the big unexpected hits. I got these springs because like you I was too late for the TSB, and the stock springs suck. The OME will haul way more then the Deavers. I looked at the Deavers but I think they would decrease load carrying over stock from what I found.
  4. Jan 5, 2009 at 4:08 PM
    das56170
    das56170 Well-Known Member
    Temecula, CA
    2007 Tacoma Access Cab 4X4 SR5
    Flowmaster cat-back exhaust, volant cold air intake, 3" lift with AAL, 285/75 r 16 pro comp xterrains, 1" differential drop, spare tire mod, hypertech in-line speedometer calibrator, debadged
    How much lift would OME Dakar leaf springs provide. I've looked at other leaf packs (allpro, alcans, deavers) and they all say that they decrease payload capacity, which is why i haven't bought any of these. I already have AAL, but they already seem to be sagging a little...and I want better on/off road handling without sacrificing too much payload capacity.
  5. Jan 5, 2009 at 4:12 PM
    sonjay
    I didn't measure anything for some dumb reason when I installed my lift, but I would say around 2 1/2" of lift.
  6. Jan 5, 2009 at 8:41 PM
    das56170
    Temecula, CA
    Where did you buy the OME leaf springs. On this website I've been reading a lot about OME coils, but there doesn't seem to be that much info about their leaf springs. Are there different spring rates or different springs for different amounts of lift.
  7. Jan 5, 2009 at 8:42 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    Deavers are great!
  8. Jan 5, 2009 at 11:10 PM
    das56170
    Temecula, CA
    Does anyone have any complaints about the OME dakars? I have a 3" lift up front and seriously considering them now. (in replacement of AAL)
    So, from what I've read this is what I understand: They give a couple of inches lift while maintaining or increasing payload capacity, and they handle well. They are actually cheaper than Alcans and Deavers.
    Any further input?
  9. Jan 6, 2009 at 6:52 AM
    OU812
    danusa
    Kilroy was here
    13 DblCab LB 4X4
    So how much lift did you gain?? I don't want a lot of lift on mine. If I lift it up too high I then need to get a ball with a significant drop in it. That reduces towing capacity by virtue of imparting leverage on the drop bar which is not good.
    I see those guys in jacked up Chevy's towing with a 8" drop bar and I'm thinking that has to be stressing severly at the hitch.
    I didn't look at your build yet, what do you have up front?
  10. Jan 6, 2009 at 9:41 AM
    sonjay
    I have OME 885 up front, it will lift the back end at least 2 inches over stock. As long as you don't go over your tongue weight rating you should be fine.
  11. Jan 6, 2009 at 11:51 AM
    FL Forester
    FL Forester Well-Known Member
    Tallahassee, FL
    2014 MGM Double Cab
    2016 TRD Suspension upgrade, 1st gen TRD Wheels, 265/75/16 Cooper RTX
  12. Jan 6, 2009 at 11:59 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  13. Jan 6, 2009 at 9:01 PM
    Downsouth Motorsports
    Downsouth Motorsports Downsouth Motorsport Vendor
    Mission Valley, San Diego
    Front King 2.5, Coilovers, Camburg UCA, Rear King 2.0 Shocks, Lots of Tinted Windows, Cherry Third Owner
    Another great Idea are the Firestone Air Bags!
    You get the best of both worlds! I have them on my truck and I love them-
    Instead of adding a replacement leaf pack- or add-a-leaf that changes the ride quality, the bags are there when you need them- not too bad on price either. I tow a trailer to the desert and level the truck out-same factory ride, then when I get home just let the pressure out and again- same ride quality!
