Which States Use Dual Catalytic Converters???
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaGus, Jan 19, 2011.
  1. Jan 19, 2011 at 2:48 PM
    TacomaGus
    TacomaGus [OP] Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    I understand that some of the first gens have while some others do not have a dual cat set up, i dont know whether my truck has dual cats or not. Its from PA. I've gathered that theres cali and all other 49 states have a different set up, i'm just not sure which is which.
  2. Feb 17, 2011 at 5:23 PM
    geoff06
    geoff06 261k and counting
    WI
    '01 PreRunner Xcab lifted
    3" lift, Bilstein 5100/OME coilovers, rear AAL, Swiss camper shell, Rough Country 9000 rear shocks, 265/75/16 AT's on stock steel rims painted black, All-Pro 1.5"F/1.25"R wheel spacers, airbox elbow mod, Flowmaster Super 44, Davico post-cat, I took off my DIY angle iron bed/light bar!, bed wheel well shovel-mount, blacked out grill emblem, Poineer DEH-P3900 head unit, Alpine Type R front component speakers, Pioneer Coaxial rears, Dynamat in door panels, scratchbuilt aluminum holders for my ipod nano and phone, and for some reason, I painted the headlight fillers black...
    i have a 2001 from california and it does have what appears to be 2 cats. my CEL is on throwing P0420, indicating that i may need "a" new cat (i have no idea which one needs replacing). but as far as i know, california tacos have 2 cats. other states, not so sure...
  3. Feb 17, 2011 at 5:27 PM
    AK27
    AK27 Well-Known Member
    my truck is throwing the P0420 code, comes up as bank one cat inefficiency (pass. side closest to motor)
    i have a 2nd gen though, just thought this may help
  4. Feb 17, 2011 at 8:58 PM
    geoff06
    WI
    thanks for that info. actually that was a sneaking suspicion i had. well, in the morning when there is some light, i will go check out the area and see how difficult it will be to do the necessary work
  5. Feb 17, 2011 at 9:15 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    fwiw, my '02 is not a cali truck and it has 2 cats.
  6. Feb 18, 2011 at 5:23 PM
    geoff06
    WI
    well, mine is now in the shop being inspected for which cat is faulty (if either). if i need a new cat, i am definitely buying/installing it myself.
    sorry for a bit of thread jacking btw
    *EDIT*: just heard back from the shop, and my rear ["post"] cat is dead. time to order a new part and do the labor myself. judging by what the mechanic said, looks like all 01-04 tacos have Pre- and Post Catalytic Converters. so TacomaGus, i guess yours probably has 2 cats. you can look underneath and see for yourself- just follow the exhaust from the muffler toward the engine, and you should see 2 cats, one under the rear passenger side and one just under the front of the passenger-side floor
  7. Feb 19, 2011 at 6:39 AM
    crsdutchess
    crsdutchess New Member
    british columbia
    2001 toyota tacoma pre-runner extra cab
    woke up this morning and started my 2001 taco and it sounded like a John Deer tractor, someone sawed the #2 cat off Replacement cost 882 dollars plus repairs will cost about 1200 dollars. Apparently the cats are being sold for scrap metal for about 100 bucks! Nice huh!
  8. Feb 19, 2011 at 9:51 AM
    TacomaGus
    Gus
    Morgantown, WV
    wow dude that sucks. And yes i found that i do have dual cats, luckily i still have both of mine. Won't insurance cover that?
  9. Feb 19, 2011 at 2:44 PM
    geoff06
    WI
    check ebay and local auto pick-a-part yards. you could literally save $1000
  10. Feb 20, 2011 at 6:02 AM
    crsdutchess
    british columbia
    I bought the cat from Toyota along with the O2 sensor but because the pipes were cut off I have to buy the entire exhaust system as the flanges are missing from the engine and to the tail pipe. Going to be expensive for sure and yes the insurance will cover it I hope as we are still trying to settle with them.
  11. Feb 21, 2011 at 3:50 PM
    geoff06
    WI
    oh yikes, i didnt realize it was that bad. best of luck with the insurance company!
