which sub for 4 channel amp
Discussion in 'Audio & Video' started by Amo-cat3, Dec 18, 2010.
  1. Dec 18, 2010 at 11:16 AM
    Amo-cat3
    Amo-cat3 [OP] Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Want to just stick to one amp if possible.
    The amp is Pioneer gm9500 75rms x4x4ohm. I will use this to run id ctx65cs up front. I can bridge 2 channels for 200 rms for a sub. Is 75rms for component ok and 200rms for single sub. If so which sub do you recommend. I have a dbl cab and don't need to hide a sub behind rear seat, just something small that can be easily removed if i need backseat space (never have passengers only dogs).
    I already have a small sub box that can fit a deep 12", but just want a decent sub to run off the bridged amp. Or should i just bridge the amp to 2 channel and push the component speakers with 200rms.
  2. Dec 18, 2010 at 1:38 PM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    You don't have enough speaker to bridge the components to 200W. 75W each should be fine. Which sub you choose depends on the box you have. Try to find something that matches the box well that can run around 250W RMS and you should be fine.
  3. Dec 18, 2010 at 4:09 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    dolbytone,
    thanx for replying, i was hoping 75rms was enough for components. So a 250 rms max. sub is what i should look for? I'm just going to keep it simple and get a SVC 4ohm sub - any recommends that i should look at.
  4. Dec 18, 2010 at 9:01 PM
    WTtoolman
    WTtoolman Facial bones colapse as I crack your skull in half
    William
    Omaha, NE
    2006 Access Cab 4x4 TRD SWB
    5100s at 0, eibachs, 2" toytec AAL,, Moto Metal 951b, BFG A/T
    Hey Amo! That is the exact amplifier I purchased to do exactly what you want to do! I use the front channels for the components(MB Quart PVI 216) and bridged the rear channels for the subwoofer(Polk MM1040) The components sound incredible. The sub could use a few more watts but it sounds really good considering I was going for sound quality and not cab-shaking bass. A fantastic amplifier and extremely small!!
  5. Dec 19, 2010 at 1:31 AM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    :yay:
    Right On! u just got me all riled up thinking of all my stuff that's on order. I'll never sleep now. Aloha
  6. Dec 20, 2010 at 1:52 AM
    shaneckc
    shaneckc Fyntünd Designs Vendor
    Shane
    Thousand Oaks, CA
    2014 SR Package DCLB 4x4
