Which suspension and tire setup should i go with?
Discussion in '4 Cylinder' started by Hunter'06FLKY, Jan 18, 2010.
Which suspension setup?(read options below)
Poll closed Feb 17, 2010.
  1. Option 1
    23 vote(s)
    54.8%
  2. Option 2
    11 vote(s)
    26.2%
  3. Option 3
    8 vote(s)
    19.0%
  1. Jan 18, 2010 at 6:47 PM
    Hunter'06FLKY
    Hunter'06FLKY [OP] Well-Known Member
    Central Florida
    08 Access Cab SR5 4x4
    Bilstein 5100's on all 4 corners, OME 884's, Toyotec AAL, Differential Breather, PIAA Fog's, K & N Air Filter, Definity Dakota M/T's, Cherry Bomb Extreme High Clearance
    I drive a 2008 Tacoma SR5 4 cyl. and I'm trying to decide what I should do with my suspension. I have a couple options and need some help deciding. I currently have the stock suspension and tires.
    Option 1: Bilstein 5100's set to 2.5 with and 1.5 in. progressive add a leaf in the rear with 265/75R16 Wrangler Duratracs load range C to cut back on the weight.
    Option 2: Bilstein 5100's set to 1.75 with no change in the rear and 245/75R16 Wrangler Duratracs
    Option 3: Some different combination(please post).
  2. Jan 18, 2010 at 6:48 PM
    Tsenekos
    Tsenekos Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    I like option#1
  3. Jan 18, 2010 at 6:51 PM
    Cwagner588
    Cwagner588 Member
    Clint
    Marietta ohio
    silver 4wd 4cy
    3 inch lift 33s
    go big i went 3 and not big enough with 285s cant tell its lifted really
  4. Jan 18, 2010 at 7:15 PM
    hwork50
    hwork50 Well-Known Member
    San Clemente
    06 PreRunner SR5 AC
    DTRL, Skid Plate, Bed Extender, ipod hook up in glove bo, bed mat, rubber mats, Garmin GPS, 2.5"Toyotec lift with 5100 shocks and Eibach springs.
    I wonder what the 265's weigh as the stocks weigh 34lbs. I did the 5100 lift and the toyotec springs. I also did the AAL in the back. I could not be happier with things. I still have the stock tires and get close to 25 mpg.
  5. Jan 18, 2010 at 7:38 PM
    Hunter'06FLKY
    Central Florida
    the 265's weigh 45 lb's and the 245's weigh 40 or 45 depending on the load range.
    do you have any pictures of your truck set up like that?
  6. Jan 18, 2010 at 8:03 PM
    hwork50
    San Clemente
    06 PreRunner SR5 AC
  7. Jan 18, 2010 at 10:52 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    camburg spindles ftw! with some adjustable coilovers and a nice aal in the back
  8. Jan 18, 2010 at 10:52 PM
    kilgoja
    kilgoja Well-Known Member
    Alabama
    2009 regular cab 4x4 2.7L (silver)
    :mudding:
    go with 5100's set at 1.75 with 265/70/16 or 265/75/16 tires
  9. Jan 18, 2010 at 10:53 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    After seeing your truck I'd say go with option 1 for sure :) But keep in mind once you go 2.5 or higher you'll need new UCAs :)
  10. Jan 18, 2010 at 10:54 PM
    ColtsTRD
    Scott
    AZ
    Yea thats a better choice :cool:
  11. Jan 18, 2010 at 10:58 PM
    m_yota
    m_yota Well-Known Member
    Paradise
    08 4x4 dbl cab
    K&N airfilter, HID conversion for headlights/fogs. Wet Okole Seat covers, Kove Aphex processor Kenwood comp 6.5" and 6.5"coaxial 5100 billy shocks 2.5", 1.5" fabtech AAL,Epicenter and MTX Sub, debadged, tinted, kenwood dnx812, black mesh grill, led ext/int.
    I would go with option 2. I am half way I just need the tires.
  12. Jan 18, 2010 at 11:00 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    option 3: 5100's set @ 1.75, tsb aal, and 265-75-16.
  13. Jan 19, 2010 at 12:17 PM
    Hunter'06FLKY
    Central Florida
    i would love this option but unfortunately i am a poor college student.
  14. Jan 19, 2010 at 12:18 PM
    Hunter'06FLKY
    Central Florida
    does anyone have a pic of a setup like this?
  15. Jan 21, 2010 at 6:40 AM
    Black08Taco
    Black08Taco Well-Known Member
    Baltimore,OH
    09 Super White Double Cab long bed
    Stock....For now
    This is the same set up I have and it look great and rides great. Ill see if i can get a pic. for you tonight or tomorrow. Same tires also... great choice
  16. Jan 21, 2010 at 9:55 AM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    is MPG and lose of power gonna be a big deal deal for you?
  17. Jan 22, 2010 at 8:34 AM
    Hunter'06FLKY
    Central Florida
    that's my main internal struggle right now with it. i really like getting 20-25 mpg. as far as a loss of power i'm more worried about that off-road than on-road.
  18. Jan 22, 2010 at 12:00 PM
    kilgoja
    Alabama
    :mudding:
    i'm gettting the 5100s and the OME 883 springs...will get about 1 1/2" lift up front at the 0" setting
  19. Jan 22, 2010 at 1:05 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    Keep us updated on this option. How does the 883 differ from the 884, and is there a reason you are not going with the ome shocks?
  20. Jan 22, 2010 at 3:38 PM
    TacomaTSP4
    TacomaTSP4 Go Big or Go Home!!
    Travis
    Rohnert Park, CA
    option 3....bilstein 5100s set at 2.5 with top plate spacer to get full 3" of lift and then 2" AAL in rear and then put some 285's on there so you have the 33" tires. Ive got the 3" in front and 3" in back on 285's and i love it.
