Which suspension should I choose?
Discussion in 'Suspension' started by j10munoz, May 22, 2020.
  1. May 24, 2020 at 9:15 AM
    TacoTime850
    TacoTime850 Always Maybe Sometimes Never
    Everywhere and Nowhere
    2019 DCSB 4x4
    2.5” lift, Fox 2.5 ext tvl adjustable w/ DSC, SPC adjustable UCAs, Icon RXT leaf pack, Superbump stops, 17x9 Fuel Podium Bronze wheels, 285/70/17 Cooper STT Pro
    Im lifted at about 2.5” with 285s and I didn’t do a CMC or trimming. All you need is an adjustable UCA.
  2. May 24, 2020 at 9:42 AM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    For budjet 3" lift, check out the suspension option @shouldveboughtajeep is running here with pictures here (Tuff Country UCA's for $300). He also goes into here, and at some point does a :notsure:
    j10munoz[OP] likes this.
  3. May 24, 2020 at 12:47 PM
    angerbot
    angerbot Well-Known Member
    Depends a lot on wheel offset/width and which particular tire. It's something to be aware of anyways.
    Basically it'll boil down to you can spend ~$1k doing a CMC and wheel well work assuming you farm it out to a shop, or you can spend $1k to buy and install new UCAs to avoid the trimming. Either way going to a 285 is going to cost you more than just the suspension lift. I didn't see OP mention anything about it in their budget, so wanted to call it out as a point of concern.
  4. May 24, 2020 at 3:01 PM
    greywater4x4
    greywater4x4 New Member
    2010 silver access cab 4x4
    nothing big.
    from what ive researched uca's might not help with fitment much mostly correcting alignment?? my'10 access cab taco is getting a 2.5" front and 2.75rear lift kit from headstrong. hopefully will be all I need for 285 75 R16 or 17's. thoughts anyone? hopefully wont HAVE to do much trimming etc.:fingerscrossed: cant really find any info on exact set up as what I want...odd. :help::itllbuffout:
  5. May 24, 2020 at 3:51 PM
    TacoTime850
    2019 DCSB 4x4
    Adjustable UCAs, such as SPC will allow the front tire to move a good bit more forward. Eliminating the need for a CMC for almost all applications. If you get wheels with a very big offset then you might still need to do a CMC.
    Non adjustable aftermarket UCAs have built in caster to help with articulation and alignment after a lift. The problem is that the built in caster is positive on the UCA which moves the tire further back towards the cab mount and causes rubbing. Many people are confused by the built in caster of a UCA. They think the built in caster helps with fitting bigger tires. It doesn’t. It actually makes the rubbing worse.
    Your factory UCA will clear larger tires better than an aftermarket one unless it is adjustable.
    Positive caster on the upper control arm will move the tire back towards the cab mount.
    Positive caster on the lower control arm will move the tire more forward, away from the cab mount.
  6. May 24, 2020 at 4:24 PM
    sgtnewundies
    sgtnewundies Well-Known Member
    Eric
    Florida, Citrus County
    14 trd sport red
    Working on it now....UNDER CONSTRUCTION
    You came in here asking for advice and now you say you don't need to rethink anything. Good luck with your build.
