Which sway bar end links
Discussion in '1st Gen. Tacomas (1995-2004)' started by CrippledOldMan, Oct 29, 2019.
  1. Oct 29, 2019 at 1:53 PM
    CrippledOldMan
    CrippledOldMan [OP] Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    Truck is a 2003 tacoma 4x4 V6 limited edition. Just curious if it makes a difference which brand of sway bar end links everyone is using. Not really wanting to pay Toyota OEM prices. I know many of you hardcore off roaders have no sway bar, but I don't do any heavy duty off roading anymore, and like the control it gives during everyday driving. So what brand should I go with. Suggestions are greatly appreciated.
  2. Oct 29, 2019 at 2:29 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    I went with Napa chasis on one side and duralast on the other (changed at different times). I much prefer the napa version as it has 18mm wrench flats on both sides, so no need to fiddle with the allen key stripping out. It also has a grease fitting unlike the duralast. Both are around the same $30 price point.
    Heres one side
    https://www.napaonline.com/en/p/PCQ...+Link+-+Front+Susp&keywordInput=sway+bar+link
