Which taillight wire do I tap for my brake light on my camper shell
Discussion in '1st Gen. Tacomas (1995-2004)' started by cmf21, Mar 31, 2010.
  1. Mar 31, 2010 at 12:14 PM
    cmf21
    cmf21 [OP] Well-Known Member
    Arizona
    04 4x4 dbl cab trd
    Hooking up the brake light on my camper shell today. Which brake light wire on the taillight am I supposed to use or does it matter. Seems like both wires (green & the green with white wires) work from my testing.
  2. Mar 31, 2010 at 12:15 PM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    I want to say mine is in the green. Either should work by my reckoning as well.
  3. Mar 31, 2010 at 12:45 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Factory wiring to the 2004 brake lights is green with a white stripe.
    Factory wiring to the 2004 tail lights is solid green.
    If you're hooking up your shell's third brake light you'd be wanting to tap into the green / white wires.
  4. Mar 31, 2010 at 12:48 PM
    cmf21
    Arizona
    04 4x4 dbl cab trd
    Thanks. First guess was the green/white wire.
  5. Mar 31, 2010 at 1:02 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    ...The one that is going into the brake light?
  6. Mar 31, 2010 at 1:14 PM
    cmf21
    Arizona
    04 4x4 dbl cab trd
    Yeah. The wires from the brake light. I'm also going to ground the shell and the dome light to the white ground wire in the taillight as well I think. I have also ran the power for the dome light to the battery already.
  7. Mar 31, 2010 at 4:04 PM
    flightcancled
    As long as you are there run a bed outlet if you don't have one or at least the wires. If you are running one wire from the battery and ground might as well do two.
  8. Mar 31, 2010 at 5:11 PM
    Idrivetoys
    Idrivetoys Well-Known Member
    Yuma AZ
    I need a 4 door DC 4x4
    might want to up the fuse as well 5A
  9. Mar 31, 2010 at 6:39 PM
    ct-taco
    ct-taco Member
    Ed
    Connecticut
    01 sr5 v6 4x4
    265/75s,bedliner,
    Not sure if it was just mine, but when my camper shell third brakelight was plugged in, my towing trailer lights acted up, and from what I could figure out was the trailer harness didnt like the extra draw.
    Dont know if you tow, but I sussed this out only after re-doing the truck AND trailer grounds, harness conns, bulb checks etc.. :(
  10. Apr 6, 2010 at 5:55 PM
    baachor
    baachor Member
    Ramona,CA
    2014 4L V6 Prerunner King Cab Short Bed
    thanx EnolaGaia.This helped me today to wire my Snogtop shell to 1999 LX.
    Only diffference is my 99 has brake light GREEN/RED.
    The Shell got RED and WHITE. So I wired WHITE [ground] right under the hook's screw.And RED to GREEN/RED. Don't have any special tool,but it works great ;) :D
    Now just have to search for dim light,which is battery operated.Don't like that :eek:
    Thanx again for this post :)
  11. Apr 6, 2010 at 6:52 PM
    cmf21
    Arizona
    04 4x4 dbl cab trd
    I hooked the brake light wire into the green/red wire for the power and white for ground. There wasn't green/white as i thought. I also hooked up a lighted switch on the dash for my dome light as a precaution in case i forget to turn off the light in the back.
  12. Apr 7, 2010 at 9:24 AM
    baachor
    baachor Member
    Ramona,CA
    So you ran power for dome light from battery? Sorry im not electrician. And where did you ran the cabel?
    thank you
  13. Apr 7, 2010 at 9:31 AM
    cmf21
    Arizona
    04 4x4 dbl cab trd
    I ran a power cable with an inline fuse from the battery to a switch in the truck, then I ran a ground for the switch to a nearby screw and also ran another power cable from the switch to the back of the truck and hooked it into the dome light and I also hooked up the dome's ground.
    I would have just ran the power cable directly back to the dome but I wanted to have a fail safe (the switch) just incase I forgot to turn it off in the back. I'ts now kind of hard to miss a glowing orange light on the dash.
    It took a little time trying to route the wires, but I had alot of fun doing so. I bought a switch from this place. The orange light matches perfectly. http://www.oznium.com/gsw-45-led
    TRDTaco420 likes this.
  14. Apr 7, 2010 at 10:28 AM
    baachor
    baachor Member
    Ramona,CA
    thank you,
    just ordered the switch.great idea ;)
  15. Jul 27, 2011 at 11:01 AM
    beedoola
    beedoola Well-Known Member
    San Francisco, CA
    01' Tacoma PreRunner 2.7
    BUMP.
    figured it would be better to bump this thread than start a new one...
    I have an 01' Taco, how do I access/run the needed wires into the shell? The wire for the shell hook up is on the driver side so it makes sense to tap into the left brake light. Do I need a certain wiring harness? My Shell also has two dome lights.
  16. Jul 27, 2011 at 12:09 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    Here is how I and another member rigged up our lights.
    http://www.tacomaworld.com/forum/lighting/165051-how-interior-canopy-light.html#post3387616
    As far as your brake light, take out the driver side tail light and use a volt meter to find which wire has power to it when you tap the brakes and splice into that one. The previous owner of my truck had already tapped into the wires for the shells brake light but it wasn't hooked up to it. I went to hook it up and I think the light is bad because I have power going to it, it just won't light up. Either the bulb is bad or the the internals are bad. Either way I'm looking to upgrade to an LED light in the future. For now my shell is brake light-less :eek:
