Which tire size would fit better? TOYO ATII
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ZekeR7, Mar 2, 2018.
  1. Mar 2, 2018 at 2:51 PM
    ZekeR7
    ZekeR7 [OP] Well-Known Member
    2018 TRD Off-Road 4x4 Quicksand
    So... I had ordered skinny tires from Falken Wildpeaks AT3W 235/85/R16. But they were a little to skinny when I saw them in person so I am returning them.
    With that said, I am looking into Toyo's AT II.
    Either 265/75/R16 or 285/75/R16.
    I have a lift kit that is measured to be around 1.8" from hub.
    Please state why!
  2. Mar 2, 2018 at 3:24 PM
    Marcmtb1
    Marcmtb1 Well-Known Member
    PHX, USA
    2016 Tacoma TRD OR DCSB 4x4
    5100/885 w/ 1/4 lean spacer, Icon RXT w/ B110’s, 255/80/17 FWP, AP Apex Sliders, KDMax 87, ADD W1, BD mirror riser
    Why not 255/85/r16?
    su.b.rat likes this.
  3. Mar 2, 2018 at 3:28 PM
    phsycle
    phsycle Well-Known Member
    CA
    Do you really need 33's? I would go 265/75/16 (32"). Not as much MPG drop from stock (~2MPG), not a significant loss in power, and cheaper.
    shakerhood likes this.
  4. Mar 2, 2018 at 3:31 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    285's will be heavy and rub on your plastics likely. Will definitely look killer though.
    The ATii in a 265 is plenty of tire and won't rub . It' s appearace is somewhat nderwhelming however.
  5. Mar 2, 2018 at 3:34 PM
    ZekeR7
    I forgot to mention, I will get a cab mount chop done if need be.
    are you talking about the black plastic trims or the front bumper?
  6. Mar 2, 2018 at 3:36 PM
    ZekeR7
    Still too skinny, I need a bit wider since I am in swamp land lol. Almost bottomless mud.
  7. Mar 2, 2018 at 3:38 PM
    ZekeR7
    Does 265s would need a cab mount chop? Would it rub when suspension gets compressed while offroading?
  8. Mar 2, 2018 at 3:45 PM
    Hairy Taco
    North of Hell
    08 TRD
    My 285's have always rubbed the inside rear corner of my front fenders and some fender liner. I also have a cmc.
    I assume you realize that 285 on a stock wheel might also rub your uca?
  9. Mar 2, 2018 at 3:50 PM
    ZekeR7
    Ugh... didn't think about the UCA! Well... I'll probably get 265... Maybe later in the future, I'll get 285 when I get new wheels when these gets all scratched up.
  10. Mar 2, 2018 at 3:55 PM
    ZekeR7
    Or maybe I'll just go with Toyo R/T 265/75/R16 since they are a bit more aggressive and are 31.9" instead of AT2 265/75/R16 31.6"
    Hairy Taco likes this.
  11. Mar 2, 2018 at 3:58 PM
    phsycle
    CA
    No, it'll fit on a 100% stock truck. Possibly minimal rub at full compression and lock. But not a big deal. Plug and play.
  12. Mar 2, 2018 at 3:59 PM
    Hairy Taco
    North of Hell
    08 TRD
    If you like a beefy looking tire, I would definitely choose a different tire in a 265. The RT is nice.
    I also drive a 2nd gen. Not sure if a 285 clears the uca on a 3rd gen
