Which tire size?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheUltimateTaco, Mar 27, 2013.
  1. Mar 27, 2013 at 11:06 AM
    TheUltimateTaco
    TheUltimateTaco [OP] Well-Known Member
    2006 Toyota Tacoma SR5 PreRunner
    bull bar, running boards, window visors, tool box
    Alright im looking at two different types of tires, one being Nitto Trail Grapplers at 285/70 and BFG's All Terrain but I don't know which tire size. For a 17 inch rim what tire dimensions should I have?
  2. Mar 27, 2013 at 11:13 AM
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    265/65/17 or 265/70/17.
    Do yo have lift? Do you want to trim? Which wheels are these going to be mounted on? More info needed.
  3. Mar 27, 2013 at 12:43 PM
    TheUltimateTaco
    no lift yet but I might get a leveling kit or or a 3 inch lift with it. They will probably be put on 17" wheels, ultra motorsport, and whats trim?
  4. Mar 27, 2013 at 12:50 PM
    kryten
    Canada
    Largest tire you can put on a stock (non lifted) 2nd gen Tacoma is 265/70/17. That is also assuming stock wheels. 9 out of 10 times you can even keep your front mud flaps since your tires still won't rub them.
    Once you mount them on aftermarket wheels and if those wheels have less backspacing, (ie. 4.5bs instead of the 5.5 of stock sport wheels), be prepared to remove front mudflaps, so your tires clear or even do a minor trimming of the inner fender flare.
    For 285's, usually you need a 2.5 - 3" lift and still do some trimming.
