Which Tires are Really the Best for the $$$
Discussion in 'Wheels & Tires' started by sac130e, Apr 15, 2011.
  1. Apr 15, 2011 at 5:23 PM
    sac130e
    sac130e [OP] Well-Known Member
    Scott
    Milton, FL.
    11' TRD Off-Road 2wd
    JVC Nav. System and entire Memphis Audio Speakers/Amps
    Looking at a 265/70/17 in either BFG KO, Duratraks or Nitto TG. Going to wrap around some MM 955 17x9 on a 2-3" lift. I do no offloading/4 x 4, so strictly for road/highway. Not a lot of hauling or towing either and live in FL. Near beach, so must perform good in hot weather and on wet/windy conditions. The more miles I can get out of them the better.
    Wish I could go for some 275's, but don't think they will fit without some trimming (can't trim for now and local installer thinks the 265 is largest to fit)
    So, going to get these in current GB going on, like to pick up next week. Looking for all advise based on actual performance of tire, not just because you think this brand is better then the other.
    Thx
    Scott
  2. Apr 15, 2011 at 5:25 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    Probably the Nitto TG's out of the ones listed since they're reasonably priced and you dont need a more agressive tire for running only street. If you dont care about looks of an AT, look into higher mileage/lower resistance and better handling highway tires
  3. Apr 15, 2011 at 5:31 PM
    ontarioyota
    ontarioyota Well-Known Member
    SW Ontario, Canada
    01 reg cab 4x4
    Blacked out badges-rims OME lift with 881's & dakar pacs with D6XL AAL (removed), summer tires=BFG 31x10.5x15 on 93 4runner rims,winter= 265 75 16 DURATRACS on stock steelies,Flowmaster exhaust, deck plate mod, ARB front bumper
    I just went with BFG but for the $ and reviews I read maybe consider firestone destination at...check the tirerack ratings
    Michelins will last you forever...could be the best value if you consider cost per mile driven...plus they will ride like a dream
    Of your 3 selections I say..... BFG At ko
  4. Apr 15, 2011 at 5:49 PM
    sac130e
    Scott
    Milton, FL.
    Yup, looking to keep some aggressive look to the truck. Currently running the stock rims/tires (BFG AT) and they run smooth and quite, just not big fan of their high cost, but can overlook if they will out last all others in mileage.
    Thx for the inputs, keep them coming.
  5. Apr 15, 2011 at 6:35 PM
    sac130e
    Scott
    Milton, FL.
    Alright, after some reading posts here, switching gears slightly. It would be better in the long run with highway all season tires.
    I like the look of what's on it now (BFG Rugged Trail TA) and could stick with those for the new rims. Also looked at Michelin, but would like one that has similar look as the TA's. (never seen these up close).
    I would really like to go up to a 275 size, but need to keep diameter around 32" to avoid the rubbing/trimming issue.
    Thx
  6. Apr 15, 2011 at 6:42 PM
    CaptainFun
    CaptainFun That Guy
    Washington DC
    2005 Double Cab 4x4
    Take a look into some "milder" all terrain tires in a p-rating. Examples could be the Hancook Dynapro ATM, Bridgestone REVO 2, or Firestone Destination AT. Since you do not offroad or tow/haul heavy loads The p-rating will save you some weight and hopefully keep your miles per gallon up. The passenger also tend to cost less than the LT versions. Good luck.
  7. Apr 15, 2011 at 6:46 PM
    RelentlessFab
    Eric
    BFG is replacing the rugged trail with a 'rugged terrain' now. Check them out, seem to be getting really good first impression reviews by magazines
  8. Apr 15, 2011 at 7:04 PM
    medic2230
    medic2230 Ditch Doctor
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB
    20% Tint, OME 3"complete lift with Dakar's, Light Racing UCA's, 285/75/16 Nitto Terra Grapplers, 10 HP TW sticker, Ultraguage, B.A.M.F. Rock Sliders, MedicFab Bed Rack, Relentless front bumper
    All I've run on my truck has been Michelin LTX A/T tires and love them. Will get 100,000 miles out of this set too. I've got 195,6xx miles and this is my second set of them. I love them. They ride great and last forever! Decent tire too for mild offroading.
    Murph
  9. Apr 15, 2011 at 7:34 PM
    sac130e
    Scott
    Milton, FL.
    Does anyone have pics of what the Michelin LTX MS2 look like on the Taco
    read some good reviews on these, but like to look at them installed.
    Thx
  10. Apr 15, 2011 at 7:37 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Since you're pretty much just going for looks, I'd recommend getting a tire with small voids (the gap between the tread lugs) the tighter the gap= smoother, quieter ride, and slightly better mpg.
    Recently put a set of the Hancook Dynapro ATMs on one of the work trucks, the sidewall has some aggressive looking stuff, and they're pretty smooth and quiet. Best part is you can get a set on the truck, out the door for about $550. Worth checking out.
    No point in dealing with noise and rougher ride if you aren't going to benefit from it offroad, IMO.
  11. Apr 15, 2011 at 7:44 PM
    sac130e
    Scott
    Milton, FL.
    Read some reviews on the BFG Rugged Terrain, looks interesting.
    Guessing no one has those on yet.
    EDIT: even tire rack doesn't show in stock till end ok May on these
  12. Apr 15, 2011 at 8:37 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Airaid Short Ram Intake, 285x75R16 Mickey Thompson MTZs, 16" Konig Countersteer rims, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
  13. Apr 15, 2011 at 8:39 PM
    1Biggerwoody
    1Biggerwoody Better to be a Smart Ass than a Dumb Ass
    Montie
    Winter-Peg, Manitoba, Canada
    07 TRD Sport Double Cab
    Heard a lot of good things about DuraTracs but from what I've read they only fit up to 8.5" so might not fit your rims.
  14. Apr 15, 2011 at 11:22 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    Nittos TGs are your best bang for your buck. I have 68k on mine now and they look like they can go for a while. I really don't like the look of them too much, the sidewall is boring, but they are good tires. I've taken them in sand, snow, hills, rocks, rain, and tow with them, they've performed well.
  15. Apr 15, 2011 at 11:54 PM
    seksilumpia
    seksilumpia Well-Known Member
    Brandon
    El Dorado Hills
    05 TRD Sport DCSB
    Performance mods: TRD CAI, AFE throttle body spacer, Doug Thorley headers, TRD exhaust. Cosmetic mods: HID 10k head+3k fog lights, BHLM, T-rex 2 eyelids, billet grill (5 piece), 20% front window tint, 4% back window tint, tinted 3rd brake light, altezza tail lights, LED license plate lights, door skid protectors, slotted drilled rotors,plasti dip rims,painted rotor and drums. Interior mods: TRD seat covers, LED map and dome lights, 2 kicker 10' w/ 500 watt amp, pioneer door speakers,and Pioneer AVIC X930BT.
    Im so biased. I love Michelins because the ride is so comfortable. Some look aggressive,but i really love the ride feeling.
  16. Apr 16, 2011 at 5:39 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    I had decent luck with Cooper tires...the ATR is a good all season with some off road, but the Discover ST is an excellent tire for the money for an all purpose traction tire.
    Howard
  17. Apr 16, 2011 at 9:12 AM
    sac130e
    Scott
    Milton, FL.
    Thx for the pics, look nice and I know they are reliable, but fall into my category of 'looks like they belong on a car'. The smooth clean flow of the tread seems to take away from the effect of having a truck (just my opinion). May stick with the new BFG Rugged Terrain that are out now.
    Thx
  18. Apr 16, 2011 at 11:56 AM
    sac130e
    Scott
    Milton, FL.
    Will the Duratraks work on the MM 955 17x9 rims?
    Tire specs say 7-8.5 rim size?
  19. Apr 16, 2011 at 12:03 PM
    CaptainFun
    CaptainFun That Guy
    Washington DC
    2005 Double Cab 4x4
    The ATR is scheduled for replacement. The redesign is called the A/T3.
    There is also a new ST MAXX being released this month, I'm not sure if its a replacement for the ST or a separate product. Both are contenders for when I get new tires. :D
  20. Apr 16, 2011 at 12:10 PM
    Marazzito
    Marazzito Well-Known Member
    Dublin, CA
    07 DC TRD Off-Road 4x4
    TRD Exhaust, AFE Cold Air Intake, URD Short Shifter, OME 886 HD Lift OME Rear Springs With XL... TRD Supercharger Coming Soon.
    Khumo SA/T... I put them on my truck because the General Grabber A/T 2's were on back order (also a great tire). Wow, I am a Khumo guy now. They have a really high tread wear rating, severe snow tire, ride incredibly well on the highway, good grip off road, excellent in the snow and very good in the rain. Oh and they are very well priced. I don't think I will put any other A/T on my vehicle.
