Which tires are recommended??
Discussion in 'Wheels & Tires' started by Zac808, Nov 6, 2009.
  1. Nov 6, 2009 at 9:48 AM
    Zac808
    Zac808 [OP] Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    I'm not sure what the difference is besides price. But which one to I need for my 08 DC??
  2. Nov 6, 2009 at 9:51 AM
    98tacoma27
    Ben
    Not Beech Creek
    The load rating is higher on the bottom one. It will be a little heavier.
  3. Nov 6, 2009 at 9:53 AM
    01tacoprerunner
    01tacoprerunner 01 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    I would go with load range D tires, they will ride better than the Load Range E tires. THe load ranges have to do with the sidewall stiffness(I think correct me if im wrong) and how much you would be towing or hauling.
  4. Nov 6, 2009 at 9:53 AM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    In turn, burning more gas??
  5. Nov 6, 2009 at 9:55 AM
    98tacoma27
    Ben
    Not Beech Creek
    Possibly, if you don't tow or pull a lot then I would go with the lower rated but that's jusy my $.02.
  6. Nov 6, 2009 at 10:07 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    The difference is load rating. The 'D' is a 8ply, the 'E' is a 10ply tire. A load D is more than adequate for our little trucks. I have load C tires(6 ply) and tow over the max tow rating with no problem. The higher the load rating is, the rougher the ride is gonna be and the heavier the tire will be. As mentioned, the increases rotational mass will reduce fuel economy a tad and also make acceleration slightly slower as well.
  7. Nov 6, 2009 at 12:05 PM
    BlissTaco
    BlissTaco 2022 TRD Offroad
    James
    San Diego
    22 TRD Offroad 4x4
    Kings, Method 701, Toyo AT3 285/70R17, interior/license LED's, tonneau cover, Subaru tweeters
    I recently put on 265/75 load range E and I have noticed a difference in power/mpg, but I can only compare to the stock 265/65 tires. I wish I would have gone with D seems to be the best option.
  8. Nov 6, 2009 at 2:06 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    im running standard ply 265s with no issues at all.even pull trailors.rides great to.less $ as well.
  9. Nov 7, 2009 at 4:26 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    What is the brand you are looking at??
    Where are you going to buy them??
    Discount tire and 4 wheel parts price match, so find then cheap online then take the website to the store and have them match or beat the price. I got the best deal w/install and rims at 4 wheel parts ;).
    Go with the lowest load rating available, not less than 2300lbs, to maintain your ride quality and mpg.
    I have P-passenger rated Nitto TG all terrains which are rated at about 2500lbs, my stockers were 2300lbs, so my mpg didn't change and my ride remained plush. The traction of the all terrains was much better than the dunlops I had.
    Also the lower load ratings will usually be cheaper.
  10. Nov 7, 2009 at 5:42 AM
    98tacoma27
    Ben
    Not Beech Creek
    http://www.wheelsforless.com/detail.aspx?ID=4770
  11. Nov 9, 2009 at 5:40 PM
    FoxySandChick
    Kristin
    Henderson, NV
