Which tires for my Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2wheelfox, May 20, 2024.
  1. May 20, 2024 at 11:30 AM
    2wheelfox
    2wheelfox [OP] Member
    Barry
    2013 tacoma
    Time to replace my tires. My last two sets were Nitto Trail Grapplers and they have been great. I just want something different. I've narrowed my tire selection down to these 3 options. Which would you recommend?
  2. May 20, 2024 at 10:30 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Suppose it depends what you're looking to do with it. Appears you are settled on mud terrains only? FYI your last screenshot of the Cooper STT is a different size than the other two, not sure if that matters for availability.
  3. May 20, 2024 at 10:33 PM
    TN1000
    TN1000 Well-Known Member
    2018 metallic silver TRD OR
    Work in progress
    Toyo?
  4. May 20, 2024 at 11:38 PM
    T4R_hereforbearings
    T4R_hereforbearings Dale Doback, M.D.
    WA
    08 4Runner
    I’ve bolted some stuff to it *lists cool stuff here*
  5. May 20, 2024 at 11:42 PM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    Cooper
  6. May 21, 2024 at 4:47 PM
    robson1015
    robson1015 Well-Known Member
    Bob
    New Concord, Ohio
    2009 base tacoma- regular cab- 5 speed
    Yokahama geolandar
    Thechief86, a400ryan and Squirt like this.
  7. May 21, 2024 at 4:57 PM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    Finally, someone who gets it... Superswampers are always the answer.
  8. May 21, 2024 at 5:28 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Why do you want super aggressive, noisy mud terrain’s? Do you actually use them or need them? How often do you go off roading and mudding? If you really use them then any of the 3 should be fine. Or as said by 23MGM , Superswampers are always the answer.
  9. May 21, 2024 at 5:32 PM
    Squirt
    Squirt Samsung Aficionado!
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back with a 3in Speedys Snap resonator. J&L catch can. AMP Powersteps
    GO15 A/Ts are great or the GOO3 M/Ts are great too
    Steves104x4 and Thechief86 like this.
  10. May 25, 2024 at 6:55 PM
    O'DubhGhaill
    O'DubhGhaill Well-Known Member
    2008 Tacoma TRD Sport Access Cab 4.0L V6 VVT-i6spd manual
    I replaced these with Cooper Discoverer AT3 4S in slightly larger 265 70R 17 and cannot believe the difference in all around exceptional performance. I am off on speedo by about +1.5 to 2 mph from actual GPS speed. Not sure about recalibration though. No rub whatsoever. OEM original wheels.
  11. May 25, 2024 at 7:19 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Falken A/T
  12. May 25, 2024 at 9:04 PM
    secher
    secher Well-Known Member
    2015 OR v6 6MT
    What are you trying to do? Do you off-road frequently or find yourself axle deep in mud on the regular; what is your normal use case?
    If you want them for the look, then, again, any will do. If you off-road only occasionally or are not a rock crawling, a milder tire with a wider range of capacity will probably suit you better.
    I've used Nokian tires for 10 years on all of my vehicles, and the nATs on my Dad's Jeep and my Tacoma. They work fantastically for pretty much every terrain I have encountered in both vehicles. Slush, unmaintained access roads, 8" deep mud over clay, asphalt (slightly noisy at higher speeds), dirt roads, the works. If you live in the south, I wouldn't recommend them; they are decidedly a cooler environment tire. High speed driving at 100F is not going to work well for tread life with these tires.
    But, let us know, what do you expect to do with these? Give us some more data to help us make an informed suggestion.
  13. May 25, 2024 at 9:17 PM
    Sprig
    Ken
    The OP hasn’t come back to this thread since when he first posted it. Appears it wasn’t a serious question. Guess he doesn’t care.
    2015WhiteOR and 23MGM like this.
  14. May 25, 2024 at 9:23 PM
    secher
    2015 OR v6 6MT
    Maybe he ended up being bombarded by hail and lost his power for a week. :)
  15. May 25, 2024 at 9:51 PM
    23MGM
    2023 TRD Off Road
    Maybe he reasonable concluded Super Swampers are always the answer.
  16. May 25, 2024 at 9:55 PM
    T4R_hereforbearings
    WA
    08 4Runner
    Oooh further proving versatility! :spending:
    23MGM[QUOTED] likes this.
  17. May 25, 2024 at 10:07 PM
    23MGM
    2023 TRD Off Road
    Longevity with that tread depth, superior traction, siping for wet conditions. A lot of fluff out there with the up and comers like Michelin and Bridgestone.. Can't be too careful.
  18. May 25, 2024 at 10:17 PM
    T4R_hereforbearings
    WA
    08 4Runner
    +1
    only real question: boggers or iroks, I first posted bogger given he seems to be looking for a mud tire.. :notsure:
  19. May 25, 2024 at 10:22 PM
    23MGM
    2023 TRD Off Road
    Touche... Some could consider a bogger more of a hybrid tire better suited on a Sienna or Highlander. OP will probably clarify his intentions. Too many variables.
  20. May 26, 2024 at 7:03 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    None of the above. Michelin Defenders instead, you won’t regret it…
    2015WhiteOR likes this.
