Which toyota truck engine is the best
Discussion in 'Product Reviews' started by taco52, Apr 26, 2011.
Which Toyota truck engine is the best?
Poll closed May 27, 2011.
  1. 22RE
    65 vote(s)
    37.8%
  2. 3RZ-FE
    7 vote(s)
    4.1%
  3. 2RZ-FE
    5 vote(s)
    2.9%
  4. 2TR-FE
    9 vote(s)
    5.2%
  5. 5VZ-FE
    23 vote(s)
    13.4%
  6. 1GR-FE
    29 vote(s)
    16.9%
  7. 2UZ-FE
    2 vote(s)
    1.2%
  8. 3UR-FE
    2 vote(s)
    1.2%
  9. 1FZ-FE
    4 vote(s)
    2.3%
  10. WTF is an Engine?
    26 vote(s)
    15.1%
  1. May 6, 2011 at 12:30 PM
    #61
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    22RE FTMFW
  2. May 12, 2011 at 8:58 AM
    #62
    YFZ_TRD
    YFZ_TRD 4Runner Pilot
    Lee
    Beaverton, OR
    2014 4Runner SR5
    I officially speak from experience, the 22RE is a damn fine motor. I just installed a new long block in my 87 4Runner and besides a few minor adjustments on ignition timing, it started right up and made me a happy man.
  3. May 12, 2011 at 10:57 AM
    #63
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Same experience with my old 4.9L bronco. Shot some flames out the carb on startup but it started :laugh:
    Old slow engines are always the most reliable.:D
  4. May 12, 2011 at 3:56 PM
    #64
    YFZ_TRD
    Lee
    Beaverton, OR
    2014 4Runner SR5
    Eh, yeah the 22RE is no power monster. But it moves my old 4Runner around quick enough to be fun. :D
  5. May 23, 2011 at 8:55 PM
    #65
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    What does everyone think of the new 4.6 v8? I was surprised that it created so much more power than the 4.7. And it may be too early to tell but what are everyone's views on their reliability?
  6. May 23, 2011 at 9:33 PM
    #66
    Dmonkey
    Dmonkey Well-Known Member
    Branden
    NorCal
    VZN159L (2002 DC)
    Eibach height adjust shocks in front, KYB monomax shocks in the back. Stock springs front and back. Level 8 MK6 10mm offset wheels on Cooper ATP tires (stock size)
    the 2rz is used in paradise racings corolla that is doing in excess of 1100hp. It runs a 1/4 in i wanna say mid 7s?
    We have a winner!
  7. May 24, 2011 at 6:30 PM
    #67
    tommyc
    tommyc Well-Known Member
    tommy
    4X4 SR5, TRD
    ONE THAT RUNS
  8. May 24, 2011 at 6:35 PM
    #68
    bowhunter11199
    bowhunter11199 Well-Known Member
    WTF is an engine :anonymous:..... jk 3.4 for me....
    reason:
    3.4l has power to turn bigger tires (32" +) with stock gear ratio(4.10)(just fyi if you want to change the gear ratio its like $400 for parts and if you have it done by someone its somewhere around $800-1200) so thats why 3.4L is good all around.....
    but if its for the milies either the 22r or the 2.7
  9. May 26, 2011 at 9:15 AM
    #69
    DOT
    DOT Well-Known Member
    Jobin
    Littleton CO
    2007 FJ
    3'' toytec lift
    X2
  10. May 26, 2011 at 10:27 AM
    #70
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    I voted 22re as I've beaten them beyond belief so many times and they never gave up. And I do like the 4.0 in my current tacoma. But the rebuilt, balanced, and cammed 2F in my FJ40 is a beautiful thing.
  11. May 3, 2015 at 7:56 PM
    #71
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    While I like the 22R and 22RE engines, I personally believe the modern engines like the 2.7, 3.4, and 4.0 blow it out of the water in the reliability department. The 22 was good in it's day, but the newer engines corrected a lot of the shortcomings it had which make them even better. I've never seen a 22 go over 500k with minimal maintenance like the 2.7, or 3.4 have. All 22's have head gasket problems, or timing chain and timing chain guide problems by then. While I've seen 2.7's and 3.4's hit that number with only having to change oil and spark plugs. The fuel delivery system is much more reliable and efficient in the newer engines also. The old fuel injection systems used in 22RE's were not very good and were even prone to catching on fire under the right conditions. I am not knocking the 22 down, I just think that the newer engines are better. Don't get me wrong, the 22 is still a great engine but is lacking with today's technology powering the new Toyota engines in our trucks. One thing the 22 has that ours never will is basic simplicity and ease to work on. I have a 22R carbureted engine in my '79 pickup and it's super easy to work on. The valves can be adjusted in minutes.
    I know I'm bumping a 4 year old thread, but I had to leave my 2 cents here. Also to bring this topic back to life and see what our new members that have joined since then have to say.
    Ozark_RegCab likes this.
  12. May 3, 2015 at 8:09 PM
    #72
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Because the 3.4 is in mine, obviously I must vote for it. But really, that tiny little 204 cubic inch plant does move my 4000lb truck pretty well-like the small v8s of the last era-maybe better!
  13. Jan 9, 2016 at 6:42 PM
    #73
    TreeGo
    TreeGo Member
    Alberta, Canada
    2003 3.4L V6 4x4 Xtracab Manual White Taco
    Late to this poll. Vote goes to the 3.4 (5vzfe).
  14. Jan 31, 2016 at 9:21 AM
    #74
    2004TacomaSR5
    Jon
    Montana
    Yep, most small block V8's back in the day only made 150hp or less stock, and the 5VZ-FE makes 190hp stock which is pretty impressive. Newer engines are impressive as a whole, hell, they're squeezing over 200hp out of naturally aspirated 4 cylinders now which was thought to be impossible for years but they made it happen! Tacoma V6's are impressive for what they are and often quicker than their V8 rivals in the full size segment. Add a supercharger to one and you can blow the doors off any full size truck out there in short order!
    I always have to roll my eyes at old school muscle car guys that think import cars are junk and cannot compete with muscle cars. Most tuner cars will eat a Mustang, Camaro, and Challenger's lunch any day of the week no sweat. I even own a 1969 Mustang and know it would never stand a chance against most imports.
  15. Feb 2, 2016 at 3:30 PM
    #75
    crepr12
    crepr12 Well-Known Member
    25 Limited Hybrid
    Any LS series swap
  16. Feb 2, 2016 at 5:09 PM
    #76
    2004TacomaSR5
    Jon
    Montana
    Who would degrade a perfectly good Toyota by putting GM junk in it? Haha
    straightawaykid likes this.
  17. Apr 28, 2016 at 9:44 AM
    #77
    liftedsr5
    liftedsr5 Active Member
    sr5
    3in lift, front fox coilovers.
    when you thought you were going to just vote for your v6, but apparently there more than one option...
  18. Jul 24, 2016 at 11:05 PM
    #78
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    I vote for the 5vz-fe as well but it's in my truck now. If it blows then I'll probably put a 4 cylinder Cummins in it lol just cause my friend is a diesel mechanic. Only downside to that swap is alot of modifying for it to work
  19. Jul 24, 2016 at 11:38 PM
    #79
    LeftCoastNerd
    LeftCoastNerd Old 'nuff to know betta
    Santa Cruz, California
    08 AC 4x4 OR 6sp
    I'm perfectly happy with the 4.0 1GR-FE in my 08 taco, with the 6-speed. now, its the *ONLY* toyota truck engine I've owned, although I've driven classics like 22R, and whatever 4-banger was in late 80s truck.
    engine swaps suck. just sayin. either you do it right, and it sucks an amazing amount of time and cost, or you don't, and it just sucks.
  20. Jul 25, 2016 at 10:21 AM
    #80
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    Valves stop making noise when they clearance gets too tight and they need to be adjusted.
