which transmission is faster? 4.0
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dsmooth87, Sep 15, 2011.
  1. Sep 15, 2011 at 9:06 PM
    Dsmooth87
    Dsmooth87 [OP] Well-Known Member
    11' doublecab 6spd 4x4 trd offroad
    Satoshi Grille. 245/75r16 hercules terra trac a/t. Afe pro dry s. ome 884s toytec 1.5 AAL for TSB. Twm shift knob
    which transmission is faster for the 4.0. manual or auto?
  2. Sep 15, 2011 at 9:13 PM
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    It's called driver mod. All in the driver
  3. Sep 17, 2011 at 5:54 PM
    JKD
    JKD Well-Known Member
    Faster or quicker?
  4. Sep 17, 2011 at 5:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Seems the 0-60 times I have read with the auto are slightly faster than the 6 speed. Havent seen any 1/4 mile times...
  5. Sep 17, 2011 at 5:59 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    I'd have to say the Automatic
  6. Sep 17, 2011 at 5:59 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    I thought I heard that from you haha!
  7. Sep 17, 2011 at 6:00 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Oh well heck. So I turned down the auto because it seemed sluggish to me. Dangit.
  8. Sep 17, 2011 at 6:09 PM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Is the 2nd gen auto a dual clutch or torque converter?
  9. Sep 17, 2011 at 6:21 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Yes, the auto will shift quicker, but gearing plays a huge role in this equation. Slower shifts, with lower gearing, and the ability to take it to redline can make it a race.
  10. Sep 17, 2011 at 7:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The 5 speed manual is quicker than the 4 speed auto in the 2.7s'
    Yes, but I cant remember off hand. Not sure if Level 10 is working on the new trannys yet. Superwerty has an upgrade, so you may want to ask him. Also, You may want to check your fluid if the shifts are slow, or lagging. Mine shifts tight, and fast all the time. Especially the 1/2 shift.
  11. Sep 17, 2011 at 8:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The 5 speed auto is pretty dam stout. The 4.0 isnt putting out enough power to come close to harming it. You can get close to its limits if your SC'd and modded, but stock, its like an old slant 6 in front of a 727 auto....
