Which TRD do i have?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Shakane, Apr 30, 2024.
  1. Apr 30, 2024 at 9:30 AM
    Shakane
    Shakane [OP] Member
    Was purchased last year advertised as TRD off-road. VIN# search doesn't indicate TRD info. Originally purchased in Sask, Canada. I don't believe it is a TRD Off Road but more likely a Pro or Sport given its options.
    - 2006 Tacoma v6 4x4, dbl cab, 6' box. (no TRD stickers on box or SR5 labels)
    - AC 110 volt outlet in box, switchable on dash.
    - Matching exterior handles, mirrors (powered), power windows/locks
    - hood scoop
    - rear differential differential c7 090105 0259 - LSD Oil Only sticker (mechanical limited slip)
    I've tried to search the diff part to find out if it is helicoil geared (hoping its Detroit TruTrac) or clutched mechanism but have been unable to find much in results. My guess is that its a Sport, but still not certain. Anyone have a guess?
    Edit- added pic for better description.
  2. Apr 30, 2024 at 9:36 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Pro didn't exist in 2006. You either have a Sport or an Offroad.
    Based on what you listed, you likely have a Sport
  3. Apr 30, 2024 at 9:52 AM
    Shakane
    Shakane [OP] Member
    Knowledge appreciated. I wasn't certain about the Pro option. Is it possible that its just a standard model with hood scoop, AC in the box, exterior color matched and LSD options added? I've heard there are lumbar support in the seats of the sport and this one doesn't have that? **EDIT - it DOES have lumbar (i was mistaken) Perhaps Sport didn't do those for that late year?
  4. Apr 30, 2024 at 9:58 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
  5. Apr 30, 2024 at 9:59 AM
    Squirt
    Squirt Samsung Aficionado!
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back with a 3in Speedys Snap resonator. J&L catch can. AMP Powersteps
    I'm guessing Sport with all the color matched parts.
    Shakane[OP] likes this.
  6. Apr 30, 2024 at 10:00 AM
    fatfurious2
    David
    Ashburn, VA
    I am not sure. Usually if it has a scoop, bed AC, and color matched handles, then its a sport.
    Shakane[QUOTED][OP] likes this.
  7. Apr 30, 2024 at 10:07 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Sounds like it's a TRD Sport, if you have the VIN I can drop it into TIS and see what it says.
  8. Apr 30, 2024 at 10:08 AM
    EveryDayIsTacoTues
    EveryDayIsTacoTues Well-Known Member
    2012 Pyrite Mica DCLB TRD Sport
    @Shakane like others have said, it's a Sport. TRD OR also didn't come with a DCLB (Double Cab Long Bed). SR5 wouldn't come with the amenities you mentioned, unless they REALLY modded it.
    Did you try dropping the VIN into the Toyota App vs. generic VIN Lookup? Either way, TRD Sport. If they haven't been replaced, they'll also have the Bilstein Sport shocks on it, and Sport Alloy Wheels.
  9. Apr 30, 2024 at 10:18 AM
    Shakane
    Shakane [OP] Member
    I'm gonna roll with that. :) I just paid $3500 for a new (used) frame and Toyota installed for $8000 (Canadian loonies). Toyota coated the frame in 2017 instead of swapping which hid the deep rot that i later discovered and failed inspection. Hate to report that Toyota left me holding the bag after MUCH MUCH deliberation. That with new rotors and brakes, axles, steering assembly, i've basically paid for this truck twice now. But it is the truck i've dreamed of owning. Power train is solid and the oils is golden. I didn't want to feel like a fraud by sticking on TRD Sport decals if it wasn't one. But with all the Sport options, i can't see why not? Not planning of ever selling it, so i'm not really worried about misrepresenting.
  10. Apr 30, 2024 at 10:21 AM
    Shakane
    Shakane [OP] Member
    Here is the VIN# 5TEMU52N76Z149574 I didn't see TRD options listed at all on the search i did.
    I'm not registered there but will do so. Thx. :) Edit- turns out i was registered there, but is throwing back a "Process Error" when i search the VIN. Could be the crazy Canadian registry doesn't jive? :p Will check Toyota Canada maybe. Edit - I think I do have standard rims? (pic further down) so if i put Sport decal on i'll be adding new alloy rims shocks do appear to be Bilstein (see pic). If it wasn't a Sport before, the conversion will be undetectable with those done. ;)
    These shocks look a bit tired. But they are Bilstein. Due for new ones i think.
  11. Apr 30, 2024 at 10:24 AM
    ThePositiveWay
    ThePositiveWay Well-Known Member
    SE Tennessee
    06' DCLB TRD Sport Super White
    Sony XAV-9000ES Headunit, Steering Wheel Controls, Sony ES Series Door Speakers, Alpine PWE-S8 Sub
    My 06 Sport has the adjustable lumbar support in the drivers seat
  12. Apr 30, 2024 at 10:29 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yea looks like it's an early VIN before they started putting all the package info in the database unfortunately.
  13. Apr 30, 2024 at 10:41 AM
    Shakane
    Shakane [OP] Member
    Knowledge appreciated. Made me go and double check mine and it DOES have lumbar dial on it. :p
  14. Apr 30, 2024 at 10:48 AM
    Shakane
    Shakane [OP] Member
    Hey Much thx Dm93. I really appreciate that info, wasn't coming up for me. All my arguing with Toyota over the frame might have blacklisted me. :p Realizing i have the lumbar dial now as well. I'm pretty convinced its a Sport for sure. Gonna order some decals with confidence. :p
    Pic of the diff if anyone knows if its clutched or gear mechanical? differential c7 090105 0259. Thanks for all the response and info. :)
    Dm93[QUOTED] likes this.
  15. Apr 30, 2024 at 10:52 AM
    SethM
    SethM Well-Known Member
    Seth
    Los Angeles ca
    2011 mgm tacoma trd sport 4x4
    3" toytec lift 285/75/17" tires
    Sport
  16. Apr 30, 2024 at 10:52 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The 06 Sport rear diff is a mechanical limited slip, I believe it's a clutch type.
  17. Apr 30, 2024 at 11:09 AM
    Shakane
    Shakane [OP] Member
    Sounds right Dm93. I've read some prefer geared for less potential maintenance over the clutched type. Most my driving is on a clean hwy. I did plow home in crazy blizzard in Feb this year down a country road when the hwys were closed. My other 2007 RWD 2.7L taco would have never made it. :p I was quite impressed with the traction i had getting in and out of large drifts and my driveway even with all season tires and not dedicated winter ones. I can't imagine for my general use that the clutches will go out or need replacing too soon. Have heard if I jack up the rear end can test by turning axle and taking notice that both wheels turn same direction to confirm proper operation.
    Thanks again for help and response. :)
  18. Apr 30, 2024 at 11:16 AM
    taco_rhyno
    taco_rhyno Well-Known Member
    06 DC 4x4 Sport
    OP - a Truetrac Torsen is available as a replacement for the factory clutch LSD.
    I upgraded mine when the factory LSD grew tired.
    A fantastic upgrade, seamless and effective in operation.
  19. Apr 30, 2024 at 11:22 AM
    Shakane
    Shakane [OP] Member
    Knowledge appreciated taco_rhyno. ;) i'll definitely be keen on that upgrade. Gonna check the condition and might add to the short list of upgrades. thx!
  20. Apr 30, 2024 at 12:14 PM
    EveryDayIsTacoTues
    Yep, that's definitely a Sport. Order away.
