Which truck would you choose?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rraabb11, Feb 9, 2013.
  1. Feb 9, 2013 at 2:01 PM
    rraabb11
    rraabb11 [OP] Well-Known Member
    All things be equal, and no chest thumping based on what you have:
    2009 2WD DC Pre-runner 10k miles $21k
    2006 4WD AC Manual transmission 96k mikes $12k
    Use it for work (light construction/light remodeling)
    Live in western NY
    Btw-is rust to be expected on the bottom inside of the tailgate for the older model above? Does this frame look like it should as well? Salty roads? Recalls?
  2. Feb 9, 2013 at 2:06 PM
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    Depends if you need 4x4 or not and DC or not.
    Seeing you are in NY, I would probably go with a 4x4 truck. Not sure about pricing, but up here, the AC for 12K with that mileage would be a decent price. Depending if the Prerunner is 5`or 6`bed, I would prefer if it was 6` if you need to haul stuff around for construction. AC will of course be 6`.
    The frame seems to have quite a bit of rust. I would be careful with that. There are a few horror stories of 2nd gen frame rust issues. Mine is and 07 and looks way better.
    Anyway just figured I start and offer my 2c.
  3. Feb 9, 2013 at 2:07 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
  4. Feb 9, 2013 at 2:10 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    The double cab if you take a bunch of guys with you to work. The access if you carry more supplies and would need a larger bed. 4WD is a plus also.
  5. Feb 9, 2013 at 6:07 PM
    scottw1
    scottw1 Well-Known Member
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Lighted 4wd dial, Sirus XM radio
    4x4, but I'd find an auto, not a manual. Just a personal choice.
    If you live in NY, you probably want 4wd with the winters you get.
  6. Feb 9, 2013 at 6:09 PM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
  7. Feb 9, 2013 at 6:09 PM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    the 4wd
  8. Feb 9, 2013 at 6:11 PM
    HIst8ofMIND
    HIst8ofMIND Defend Hawaii
    PJ
    Maui
    2013 MGM DCSB TRD-OR
    Personally I'd go with the lower miles and newer truck. But like everyone says it really depends on how you're gonna use it.
  9. Feb 9, 2013 at 6:11 PM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    4x4, plus 96000 mikes is a good deal for that price.
  10. Feb 9, 2013 at 6:14 PM
    HIst8ofMIND
    PJ
    Maui
    That's a lot of mikes
  11. Feb 9, 2013 at 6:17 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
  12. Feb 9, 2013 at 6:32 PM
    western88
    western88 Chris b.
    ny countryside
    2014 SR5 4x4 taco Barclona Red
    beather mod Bugsheild backup light mod egr vent
    4x4 and 6 foot bed. if use for haul stuff for work, I got AC 2012 6speed.. no issue. and v6 is good to have
  13. Feb 11, 2013 at 8:28 AM
    kryten
    Canada
    OP, did you pick one of those two yet, or are you still looking?
  14. Feb 11, 2013 at 8:30 AM
    rraabb11
    Waiting to hear about a job before I make the decision. The rust issue makes me hesitant on the 4X4, But I like the idea of not having a high car payment.
  15. Feb 11, 2013 at 8:36 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The picture you attached of the rusty frame isn't bad yet but will need to be coated soon or else it could be a problem. Check the frame rails futher toward the front to make sure you don't have any more serious rust spots.
    All things being equal, you need to make the decison as to whether or not you really need 4wd or not and also how many people you need to carry on a day to day basis. If you need a 4wd double cab then keep looking. 4wd and cab size are not things you will be happy with if you settle on them now. FWIW, I think the pre-runner is way overpriced for a 3 yr old, 2wd pickup.
  16. Feb 11, 2013 at 8:37 AM
    kryten
    Canada
    Ok, I see. Good luck, hope it works out for you. :)
    I'm surprised nobody comented on the frame rust on the 4x4. I'm no expert, but my 07 looks way better than that one pictured.
