Which tunes have gear lock
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hahnster, Aug 29, 2023.
  1. Aug 29, 2023 at 6:39 AM
    hahnster
    hahnster [OP] Well-Known Member
    2022 Tacoma 4x4 V6 AT
    3" Lift, TRD Pro Grill, TRD Skid Plate, 285x70/r17 BFG KO2's, LED Headlights, Rock Sliders
    I have a 2022 Tacoma V6 AT 4WD. I have 5.29s and 33" tires and I am looking into tunes. I like the gear locking option and trying to identify which tunes and versions have that? I have searched the forum and the answer has not been easy to find so hoping someone can fill me in.
    Thank You
  2. Aug 29, 2023 at 7:16 AM
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    Do you want a tune that will not allow your truck to downshift when you press the pedal hard enough?
    If you don't want the truck to upshift, just use S-Mode.
  3. Aug 29, 2023 at 8:55 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Sounds like a really good way to fry the OD clutch
    AmateurTaco1313 likes this.
  4. Aug 29, 2023 at 9:31 AM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    Long story short, I think you can get the gearlock option with any of the current “name” tunes, if you request it. Also changeable if you find you don’t need it.
    The early OV tunes had a gear lock option and I found it handy when towing my camper. It worked by unlocking the torque converter and staying in the gear that was selected, 4th, 5th etc, and downshifting was only accomplished by selecting a lower gear.
    The KDMax tunes can be optioned for gear lock if you want it but I’ve discovered that for my application, gear lock is not necessary because the tune makes it all work so good. With v10.0, I can get the TC to unlock, with a little pedal finesse, and stay in 4th gear (essentially gearlock) where, before KDM, and without gearlock, it would need to downshift to a lower gear. (Also, probably helps that I tow on the prairies.)
    My vehicle has stock gears, stock size wheels and tires.
    joba27n and vivid02 like this.
  5. Aug 29, 2023 at 9:42 AM
    hahnster
    Thank you for the information. I am also towing a camper which is where I would find the gear lock useful.
  6. Aug 29, 2023 at 10:25 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    Chew likes this.
  7. Aug 29, 2023 at 12:32 PM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    if you’re towing a camper, you should be in fourth gear.
  8. Aug 29, 2023 at 2:21 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
  9. Aug 29, 2023 at 9:52 PM
    hahnster
    Thanks everyone, appreciate the help
  10. Aug 30, 2023 at 6:53 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I have KDMax with GL. It's useful for road trips...the hills and wind..
    hahnster[OP] and joba27n like this.
