which type of suspension is better
Discussion in 'Suspension' started by ezjumper8, Mar 25, 2011.
  1. Mar 25, 2011 at 1:04 PM
    ezjumper8
    ezjumper8 [OP] Ethan
    ethan
    camp pendleton, ca
    white tacoma dbl cab 4WD sport
    20% tint all around, blacked out badges, flowmaster 40 series and tip, rock hood deflectors, window deflectors, home made baja bumper, 17" XDseries wheels on some nitto terra grapplers, bright white led interior lights, blue needle on white gauges, cb antenna, with cobra radio.
    im looking at 2 different types of suspensions now, and im trying to decide which one is better, (the first setup is from skyjacker platinum series coilover shocks, upper shock mounts, sway bar lowering block, leaf springs, U-bolts, a pair of skyjacker hydro 7000 rear shocks) and the other one is ( All-Pro front kit includes coilover shocks with top mounting bracket with upper control arms with uniball, ball-joint slug, and All-Pro rear kit comes with custom springs, bushings, and bilstein 5125 shocks)
  2. Mar 25, 2011 at 10:59 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    we're not ignoring you - but most folks on tw aren't running those suspension kits.
  3. Mar 26, 2011 at 11:37 AM
    ezjumper8
    ethan
    camp pendleton, ca
    howcome people don't run those kinds of suspensions?
  4. Mar 26, 2011 at 11:38 AM
    CopDoctor
    CopDoctor Well-Known Member
    Trinidad, CO
    2018 Quicksand TRD Off-Road
    skyjacker has a rep of sucking and allpro is expensive as shit
  5. Mar 26, 2011 at 11:43 AM
    delrayrasta
    delrayrasta Well-Known Member
    Paul
    Delray Beach, FL
    2011 4X4 TRD OFF ROAD
    pro comp stage II lift kit, retro projection HID headlight and fog, bullbar, bed cover and afe S dry intake.
    there is a search option and this has been talked about over and over if you just search a little instead of re posting over and over than maybe you'd find what you are looking for.
