Which u bolts to buy
Discussion in '1st Gen. Tacomas (1995-2004)' started by Pithy, Jun 18, 2025.
  1. Jun 18, 2025 at 2:30 PM
    Pithy
    Pithy [OP] Well-Known Member
    Christopher
    Idaho Springs, CO
    2004 3.4L V6 4x4 SR5 Double Cab Impulse Red
    2004 double cab
    I’m racking my brain on deciding what u bolts to get with all the options. I have the All Pro Expedition leaf springs that I will be installing soon and the U bolts are the last thing I need to complete the suspension upgrade.
    I’m not going to do the u bolt flip as my shocks are attached to the spring plates and I’d have to do a rear shock relocation. What U bolts are decent cost $40 - $80 range, yet strong?
    Do I do 9/16th? Would 5/8 even fit or would I have to drill the holes bigger? What grade?
    These are the options I’ve seen: Headstrong, Toytec, Rough Country, Wheeler’s, Barnes 4WD (5/8th only), Torch Off Road, etc.
  2. Jun 18, 2025 at 3:37 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    They're U-bolts- just get whatever 9/16" (14mm) ones you want. Keep in mind they come long, and you'll need to cut them to length.
    I'm not saying it's impossible, but I haven't heard of a u-bolt failing due a strength issue. I've seen plenty of people re use them and subsequently strip the threads when trying to re torque them.. but never like "I did a mega huck, and my u bolts broke".
  3. Jun 18, 2025 at 4:01 PM
    Black97v6MT
    Black97v6MT 365k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    Or leave them long with no trim see how it rolls...
    I saw a superb grey tundra once rolling down the 40 in NC...not sure what gen it was
    But he had the long bolt look going on under there and I sorta admired and thot that there is some badassery and wish mine weren't so hacked to fck and just left long...
    Plus that btch was hauling ass down the mountain near 100mph...I almost was able to keep in stride with em lmao
    Ps...pay up for the ones that will not get all rusty patina unless you into that look
  4. Jun 18, 2025 at 4:22 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Next time, just measure, thread the nuts on past the marks, cut on the bench, clean up the cut with a taper, and then remove the nuts, hit the exposed metal with rattle can, and done. I wouldn't ever try to cut them on the truck. Not that's impossible, but it's just so much easier to do it on the bench.
    Black97v6MT[QUOTED] likes this.
