Which UCA is better..??
Discussion in 'Suspension' started by sandman427, Jun 9, 2009.
Which UCA do you Like and Why..??
  1. Total Chaos
    55.0%
  2. Donahoe (icon)
    12.5%
  3. Camburg
    25.1%
  4. stock
    7.4%
  1. Aug 30, 2013 at 7:01 AM
    #241
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    12 Tacoma Prerunner TRD
    E&G Grill, Alpine MRX-F65 Amp, Alpine SWS-10D4 Sub, Image Dynamics CTX65cs component speakers, BHLM, TRS Bi-xenon Morimoto Mini Stage III Kit (D2S)with Halo's, LED's Fog, parking, DRL and License Plate , ProComp Wheel Series 7089, Hankook AT 315/75/16, Total Chaos Stock Length LCA, Icon 2.5 Extended Coilover Resi's, Icon Tubular UCA's, Icon 2.0 Rear Resi's, Maxtrac Spindles 4 inch lift, OME Dakar Leafs w/D29xl extra Leaf, AP U-bolt Flip Kit, Extended Brakelines, Pelfreybilt Front Plate Bumper, Pelfreybilt Rear HC Bumper, Pelfreybilt IFS Skid, Pelfreybilt Mid Skid, Rigid Industries 20" LED lightbar, BAMF Behind the Grill Lightbar, Relentless Bed CrossBars, Yukon 4.56 Gear's
    Trust me I will. I will always playing with them
  2. Aug 30, 2013 at 7:02 AM
    #242
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    I personally don't run then, but if I wanted to do a basic lift using say an OME kit I wouldn't have any problem buying a set at all.
    Out of the thousands and thousands sold and people are now bashing them because theres a pic of one broke, this is just retarded to me. These were meant to replace the factory arms and offer adjustability, not to catch air on or used to blast to through the desert with. You want to do that, spend the couple hundred extra bucks and buy a set intended more for this type of abuse. This just seems like common like sense to me :p
  3. Aug 30, 2013 at 7:11 AM
    #243
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    Build thread in sig...
    mine have been used and abused for about 4 years now. been in the air and on the rocks. it's all about the pre and post wheeling check, to ensure your safety. that goes for even the highest quality race part. I'm religous with mine, but it seems like there are very few people who do them, and even fewer who do them with enough detail. it involves more than just crawling under your truck and looking around.
    the unfortunate truth is that there are defects every now and then that you just can't catch before they go out the door.
  4. Aug 30, 2013 at 7:54 AM
    #244
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    Okay Scott, you posted it on TTORA which I'm not a member of. And I do see your point that it states "OEM". I and some others are wrong to assume that all BJ's manufacturers are compatible, and was not informed enough to reuse our factory BJ's from the original arms. I'll man up to that.
    I measured the Moog BJ's and the UCA cups prior to contacting Camburg.
    My original point is that there was no useful customer support when I needed it, and that you guys just blast people in the industry as well as your customers after the fact and steer them towards other options.
    Hey, thanks for another wonderful experience chatting with you guys now that I dont need the info anymore. ha, ha, ha...........
  5. Aug 30, 2013 at 11:04 AM
    #245
    motoxscott
    motoxscott Well-Known Member Vendor
    Scott
    Huntington Beach, CA
    2008 Prerunner
  6. Sep 3, 2013 at 1:48 AM
    #246
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
  7. Sep 3, 2013 at 7:04 PM
    #247
    HOOTERBIRD
    HOOTERBIRD Yeah You Right !
    NOLA
    2013 DCSB TRD Sport, 4X4
    • Cat Back Borla Exhaust System • Volant Cold Air Intake with Ram Air Scoop • Black FJ TRD TT 16” Wheels 285/75R16 BF Goodrich All Terrain T/A KO • Icon Extended Travel Front Coil-over Shocks • Icon Monotube 2.0 Aluminum Rear Shocks • Icon Tubular UCAs • OME Dakar Leaf Springs • Front Differential Drop Kit • OME Carrier Bearing Spacer Kit • Hardwired Cobra Radar Detector • Max Liner Floor Mats • Undercover Tonneau Cover • Black Powder coat Devil Horns, Made By Andres • TRD Low profile Carbon Fiber Radio Antenna • LED Map & Dome lights • LED front corner lights • LED Reverse lights • LED License Plate lights • Tailgate Hose Clamp Mod
  8. Sep 3, 2013 at 8:47 PM
    #248
    deog
    deog Well-Known Member
    snicklefritz
    Signal Hill
    work in progress
    gucci interior and chandelier.
    My question is for motoscott.
    Do you make a UCA for first gen tacomas and 4runners that utilizes the OEM balljoint, or is this only for later generations ?
  9. Sep 4, 2013 at 10:38 AM
    #249
    motoxscott
    Scott
    2008 Prerunner
    The very first arms we built back in 1997-1999 used the factory ball-joint in the spindle. When we developed arms using 1" uniballs instead because they are stronger and have more mis-alignment to allow for more wheel travel we phased the BJ versions out.
    The reason we offer B/J arms for the newer stuff is when Toyota redesigned the front suspension they also changed the B/J to something much larger and stronger that allows for more movement.
    - Scott @ Camburg
  10. Sep 4, 2013 at 5:00 PM
    #250
    deog
    snicklefritz
    Signal Hill
    work in progress
    excellent explanation, thank you. appreciate your answering my question.
    Your arms, are they 4130 and mig welded ?
  11. Sep 4, 2013 at 6:01 PM
    #251
    motoxscott
    Scott
    2008 Prerunner
    Yep, they are MIG welded and we use US 4130 chromoly tubing, not cheap import tubing from India, etc. that some other companies use.
    - Scott
  12. Sep 4, 2013 at 8:57 PM
    #252
    deog
    snicklefritz
    Signal Hill
    work in progress
    care to elaborate ??
  13. Sep 5, 2013 at 12:04 AM
    #253
    motoxscott
    Scott
    2008 Prerunner
    Many shops out there are cutting costs by using lower grade, lower quality tubing that's imported in. You can easily tell by the printing that is on the tubing itself to know what company and mill it came from.
    My suggestion is to know what you're buying, that's all.
    - Scott
  14. Dec 20, 2013 at 4:37 PM
    #254
    Gearheadesw
    Gearheadesw Well-Known Member
    Davenport Fl
    2016 GMC 2500hd
    some
    So what's the difference in travel between the 1.25 uni ball arms compared to the ball joint arms? I'm very much leaning towards the b.j. arms for my build. What ball joints do you recommend, Scott, for install in your arms? Part number or manufacturers, no endorsement, just long term durability.
  15. Dec 24, 2013 at 4:31 AM
    #255
    Gearheadesw
    Davenport Fl
    2016 GMC 2500hd
    some
    Bump for Scott, see above.
  16. Dec 26, 2013 at 3:16 PM
    #256
    motoxscott
    Scott
    2008 Prerunner
    Sorry haven't logged in for a while.
    Wheel travel will be the same between the two arms with most off-the-shelf coilovers. The 1.25" uniball has the ability to have more wheel travel since it has more movement/mis-alignment if the coilover allows for it.
    As far as ball-joints go we recommend the OEM Toyota ball-joint. That's what the arm was designed around using. Their are aftermarket versions available but the quality of them is much lower compared to the Toyota part and their quality control is also not as good. Many times the aftermarket versions do not press into our arms correctly without modifying them slightly because the body of the ball-joint is larger in diameter many times.
    - Scott @ Camburg
  17. Dec 29, 2013 at 12:41 PM
    #257
    Gearheadesw
    Davenport Fl
    2016 GMC 2500hd
    some
    Thanks Scott. Those where the answers I was looking for. My stock ball joints have just under 50k miles on them, suitable for install into new arms?
  18. Dec 29, 2013 at 5:37 PM
    #258
    motoxscott
    Scott
    2008 Prerunner
    I don't see that being a problem. If the boots are in good shape and their is no play in them ... run them.
    Down the road when it comes time to replace them, track down some OEM ball-joint take off's or if in a pinch you can get MOOG versions and if they measure too big in diameter you can chuck them up in a lathe real quick and shave off .005" +/- to the OEM dimensions so they press in correctly.
    - Scott @ Camburg
  19. Dec 30, 2013 at 4:42 AM
    #259
    Gearheadesw
    Davenport Fl
    2016 GMC 2500hd
    some
    Thanks Scott. Good info passed along there. I appreciate that. New light in the build process.
