Which UCA is better..??
Discussion in 'Suspension' started by sandman427, Jun 9, 2009.
Which UCA do you Like and Why..??
  1. Total Chaos
    55.0%
  2. Donahoe (icon)
    12.5%
  3. Camburg
    25.1%
  4. stock
    7.4%
  1. Nov 28, 2012 at 8:08 PM
    #161
    genrec
    genrec Well-Known Member
    Anyone running the ICON Tubular arms yet..feedback?
  2. Nov 28, 2012 at 8:23 PM
    #162
    superswamper003
    superswamper003 Taco
    Hendrik
    N. Snottsdale Arizona
    1998 4wd TRD 3.4l Tacoma Xcab 313k miles!!!
    Fox Xtended travel coilovers w/resis, AllPro UCA's, AllPro 3 inch leaflets, 1" Diff Drop, 285/75/16 Bfg KO, 16x8 Black Pro Comp Steelies, AP 1.25" wheel spacers in front, 8 inch Rockford Fosgate sub that bumps like your mother, old school deck, downey headers, cold air intake, grey wire mod, e-locker, hurst shift knob, LED Strips, USMC Decals FTMFW, Fox decal, Billet grille, Alarm with no remote, Straight piped to the side of the truck
    My AllPro UCA's should hopefully get here by saturday! Cant wait to install them.
  3. Nov 28, 2012 at 8:38 PM
    #163
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    I overheard you can run 35s for some reason on a 3 inch lift with these. When I heard this i thought it was BS. I figured That it would still require TONS of trimming, but the individual (cant remember name) said that they allow more space for a 35 to run. Never heard heard anything like it though
  4. Nov 28, 2012 at 10:06 PM
    #164
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    You end up trimming so much for 35s anyway, that a couple fewer degrees of castor that could be attained wouldn't matter. in fact, in order to adjust the castor to yeild a notacable benefit with the UCA, you would likely decrease the castor to the point that you would have a nearly verticle steering axis, creating less than desirable handling.
    which aftermarket UCA you have is not going to make or brake your effort of fitting 35s.
    the lift height (with the exception of a drop bracket or long travel) also doesn't matter. you have to do the exact same work to fit 35s on a 3 inch lift, and no lift.
  5. Nov 28, 2012 at 10:11 PM
    #165
    503TRD
    503TRD Trucker
    Chad
    Tualatin, Oregon
    '10 4x4 DC TRD Sport
    Front Bilstein 5100's Set @ 2.5", Rear Bilstein 5100's, Rear TSB, Rear 1.5" ToyTec AAL, 1" CB Drop Kit, N-Fab Nerf Steps, WeatherTech All Weather Rubber Floor Mats, Grillcraft Grill(Upper/Lower), Blacked Out AC Condenser/Radiator, Tinted Front Windows, Vision X H4 SuperWhite Headlights, Halo H10 Solaris Yellow 45w 3000k Fog Lights, K&N Air Filter, Removed Front Mud Flaps, 18" MagnaFlow Muffler, Chrome Exhaust Tip, TRD Logo Leather Shift Knob, LED License Plate Lights, LED Interior Lights, LED Reverse Lights, LED Auxiliary Reverse Lights, Chrome TRD Badge on Tailgate, Redline Tuning Elite Hood Struts, Disabled Seatbelt Chime, Foglights Anytime, ScanGauge II, 13" Stubby Antenna, Flyzeye Design LED Light, Cobra 19 CB Radio/Firestik II Antenna, 18x9 Raceline Raptors, LT275/70/18 Hankook Dynapro ATm, 1.25" Sidertrax Wheel Spacers, Heated Front Seats, LED Tailgate Bar, 11" Double Row LED Bar Behind Grill
    I have 5100's set @ 2.5" and 33s and 1.5AAL and stock UCA's..alignment is decent as in no poor tire wear and it drives straight..but wanders a little at 65...and if its windy out then i get blown all over...would LR UCA's fix all this?
    EDIT: Tires also rub stock UCA at full lock..I have spidertrax just havent gotten to install them yet...would LR's fix that also?
  6. Nov 28, 2012 at 10:13 PM
    #166
    the.sight.picture
    Nick
    Blue Ridge
    2018 QuickSand
    Thank you for confirming that. I figuered that the tires wouldnt just "magically" fit with those, or everyone would be running them
  7. Nov 28, 2012 at 10:23 PM
    #167
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    purely from a mathematical standpoint, it will move the tire in the right direction, but not much. being that you are adjusting the uca (top of the spindle), and your point of concern (centerpoint of the hub) is near the bottom of the spindle, you get a very small amount of wheel movement for a large adjustment of the UCA. the cost/benefit ratio (ride sacrifice/tire clearance) just isn't very good.
    quite doable though if you have the tools, and don't mind cutting up parts of the truck.
  8. Nov 28, 2012 at 10:25 PM
    #168
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    what do your alignment numbers look like? you could be wandering for a couple reasons. your alignment may not be desirable (UCAs can fix that), or it may just be that lifted trucks are wander and are more succeptable to wind that stock height trucks.
    depending on how oyu set up LR UCAs, they may help with the rubbing issue, but the spidertrax deffinately will.
  9. Nov 28, 2012 at 10:27 PM
    #169
    503TRD
    503TRD Trucker
    Chad
    Tualatin, Oregon
    Don't remember the numbers..alignment was done awhile ago..I'd say it wanders cuz its a combo of still being on stock UCA's and that I'm lifted...Ideally I'd get the spidertrax installed and LR uca's and hopefully i'd be good to go...just can't really afford the LR's right now...are spidertrax safe? even off road?
  10. Nov 28, 2012 at 10:32 PM
    #170
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    did you have it realigned after the lift? if no, that's your issue. it also could be out of alignment if it was done long enough ago. If your alignment is good, there isn't a handling benefit to aftermarket UCAs. if not used for alignment correction, their benefits are durability, and the ability to cope with the extra travel of an extended travel coilover.
    spidertrax are plenty safe. i (and many others) have been wheeling and towing with mine for 4 years. they've taken many a hard hit, jump, etc over the years and have no signs of fatigue or other damage.
  11. Nov 28, 2012 at 10:34 PM
    #171
    503TRD
    503TRD Trucker
    Chad
    Tualatin, Oregon
    Yes it was done after the lift, and I haven't done any wheeling or anything that could have knocked it out of aligment since...I really wanna stop the rubbing issue, think I should install the spidertrax, see how it handles and not really worry about UCA's for now?
  12. Nov 28, 2012 at 10:36 PM
    #172
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    That's your call. assuming the alignment is still good, it just depends on how bad your wandering is.
  13. Nov 28, 2012 at 10:45 PM
    #173
    503TRD
    503TRD Trucker
    Chad
    Tualatin, Oregon
    Yeah..I'll probably get around to doing the spidertrax, see how it handles then go for UCA's if it's worse or still bugging me. Thanks for the help man!
  14. Nov 28, 2012 at 11:08 PM
    #174
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    How are wheel spacers going to improve wandering at speed ?
  15. Nov 28, 2012 at 11:18 PM
    #175
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    vvvvv
    the spacers will only get rid of your UCA rubbing. maybe you'd notice increased stability with a 5 inch spacer on each side (no, these don't exist and never should), but you won't know a 1.25'' spacer is there.
  16. Nov 29, 2012 at 9:54 AM
    #176
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Let us know if you can get a caster setting less than about 4.5* lol
  17. Nov 29, 2012 at 10:28 AM
    #177
    superswamper003
    Hendrik
    I doubt it :rolleyes:, but thats not too big of a deal for me really. They are supposed to arrive on friday according to the UPS tracking system
  18. Nov 29, 2012 at 3:35 PM
    #178
    nubbs
    nubbs Only from the waist down.
    Reverend
    Fontana, Ca
    06 PreRunner TRD
    3.5" CST Spindle, 5100 Series Bilstien Shocks, 1 1/4" Spidertrax Wheel Spacers, 295/75/16 BFG AT's, EBC Slotted and Dimpled Rotors, EBC Green Stuff Pads, K&N Drop-in, Pioneer Avic-Z110BT GPS Head Unit w/ E-Brake Mod, Ipod Integration, Integrated Pioneer XM Radio Receiver, 6 1/2" Infinity Kappa Separates, 6 1/2" Infinity Kappa Coaxles, Custom Speaker Adapters, PAC Stealth Backup Camera (Because anyone in a double cab knows you can't see the tailgate.)
    The wheel spacers won't do anything for the wandering, other than potentially making it worse. You're put the tire further away from the axis point, which just creates more leverage. Good call.
  19. Nov 29, 2012 at 3:40 PM
    #179
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^X2 Increased scrub radius causes more wondering. I noticed this going from +32 mm offset stock wheels to 0mm Kongis. Going from +32 mm to 0 mm offset is similar to getting 1.25" wheel spacers. In 4WD there's also more torque steer.
  20. Nov 29, 2012 at 4:35 PM
    #180
    nubbs
    Reverend
    Fontana, Ca
    06 PreRunner TRD
    As well it will increase the affects of any imbalance in your wheel/tire assembly.:thumbsup:
