which UCA?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco89, Apr 13, 2011.
  1. Apr 13, 2011 at 2:14 PM
    Taco89
    Taco89 [OP] Well-Known Member
    Nik
    Charlotte, NC
    2013 4x4 Super White DBL Cab TRD Sport
  2. Apr 13, 2011 at 2:16 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    The one is a balljoint UCA the other is a 1.25" Uniball,
    There's a whole thread on UCA's, I'd find it but i'm on my phone
  3. Apr 13, 2011 at 2:19 PM
    Taco89
    Nik
    Charlotte, NC
    So I'm guessing I'll be better off with the uniball
  4. Apr 13, 2011 at 2:20 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Really depends on what you want to do with your truck. If you wanna race and run it Offroad really har uni balls are your answer. If it's just a dd with some light trails you'll be fine with the uni ball
  5. Apr 13, 2011 at 2:25 PM
    Taco89
    Nik
    Charlotte, NC
    Is there a code for it?
  6. Apr 13, 2011 at 2:29 PM
    theduck911
    Max
    Locked and Geared!
    Just mention you're a TW member, usually have to order direct to get discouts
  7. Apr 13, 2011 at 2:32 PM
    Taco89
    Nik
    Charlotte, NC
    Yeah I don't go offroading or anything
  8. Apr 13, 2011 at 2:40 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    Denver/Phoenix
    11' Tacoma & 84' Yota
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Toyo R/Ts, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tints, 2 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, JBA Long Tubes, URD o2 sims, Trail Gear bumper/Sliders, Crown brake lines F/R
    What about Total Chaos?
  9. Apr 13, 2011 at 3:07 PM
    Taco89
    Nik
    Charlotte, NC
    Are those better than the camburgs?
  10. Apr 13, 2011 at 3:20 PM
    theduck911
    Max
    Locked and Geared!
    The Camburgs are superior because of their 1.25" which makes them stronger then the 1" Total Chaos uses, also (if I'm not mistaken) they do not bind like the 1" Uniball at certain amounts of travel, both Camburg & All-Pro use 1.25" Uniballs for their UCA's
  11. Apr 13, 2011 at 3:31 PM
    Taco89
    Nik
    Charlotte, NC
    Yeah il prob go with the 699 UCA's
  12. Apr 13, 2011 at 3:42 PM
    theduck911
    Max
    Locked and Geared!
    Yea, look around too, sometimes ppl sell them used and what not!
