Which uca
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bajamoon, Mar 11, 2009.
  1. Mar 11, 2009 at 7:09 AM
    bajamoon
    bajamoon [OP] Well-Known Member
    STEVE
    Whittier
    getting ready to pull the plug on new uca's. Leaning towards Camburg with the 1.25" uni ball(on sale@ trdparts4u.com for 599), or all pro or total chaos. Like the Camburg because i want their coilovers and they do installs and they are 30 minutes from my house. What is best form you experiance. Any help would be great.
  2. Mar 11, 2009 at 7:11 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    TC's seem to be less maint, and no noise. Camburg is a good UCA, just noisey. Same with All Pro (from what I have heard)
  3. Mar 11, 2009 at 7:20 AM
    bajamoon
    STEVE
    Whittier
    what is the noise from, the uni ball? and what maintaince.
  4. Mar 11, 2009 at 7:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes, Camburg and All Pro have noisey Uniballs. By "Maintinance", they need to be greased every so often...maybe once every 6 months or so depending on use.
  5. Mar 11, 2009 at 7:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The bushings need the grease, not the Uniball.
  6. Mar 11, 2009 at 7:29 AM
    bajamoon
    STEVE
    Whittier
    ok got ya, thanks Chris
  7. Mar 11, 2009 at 7:49 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    Total Chaos FTW!
    Just don't use PB Blaster on the Uniball! :)
    And install it yourself - save the cash. Very easy install, just takes time. I did my lift myself with no prior mechanical experience. All is just fine!
  8. Mar 11, 2009 at 7:59 AM
    bajamoon
    STEVE
    Whittier
    what is pb blaster and i will look into tc.
  9. Mar 11, 2009 at 8:01 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  10. Mar 11, 2009 at 8:23 AM
    Bearskill
    Bearskill Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    Total Chaos all the way!!!
  11. Mar 11, 2009 at 8:44 AM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    having the total chaos uca's, I would say get the TC's :)
    I almost went the camburg way, they have the nice ABS wire holder too.
    But in the end it came down to the TC having built in caster correction to get ya back in specs for your alignment when you raise the truck. It's a smooth ride, seems even better than stock(smoother, not so squirly at speed). Haven't heard a peep from the uca's at all since install in Jan 09. Make sure you pre grease the bushings on assembly with any uca's.
    good luck
  12. Mar 11, 2009 at 8:46 AM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    tc's...................:d
  13. Mar 11, 2009 at 8:49 AM
    dud122
    dud122 rabble rabble rabble
    Dan
    Riverdale Park, MD
    2002 Tacoma DC
    OME up front, Dakar in the back, Elite front bumper, Warn winch, Tactical rear bumper with tire swing/jerry cans/hi lift, Revenge Fab. sliders, Tundra brakes, Camburg UCA's, Safari Snorkle, FJ TRD wheels, Truxedo, Bed Rug, Lights, CB, Switches, skids, LED's... OH MY!
    what is the difference in performance and maintenance with the camburg uniball UCAs vs. the camburg ball joint UCAs (other than about $200+)
    i just picked up a pair of used camburg uniball UCAs for 250 shipped but i'll need to get new slugs (extra $100 from camburg)... but still 350 shipped is a sweet deal!
  14. Mar 11, 2009 at 9:56 AM
    toku58
    toku58 Well-Known Member
    HAWAII
    4x4 Beast!
    6" Fabtech Stage II, 17x9" Centerline Eclipse rims, with 12.5x35x17" BFG KM2's. On board air system,Toyota skid plate, spidertrax wheel spacers, TRD CAI w/AFE ProDry filter (21-90045),Flowmaster Dual exhaust, GrillCraft grill w/custom emblem, Custom Shifter, BushWacker fender flares, Hood struts, Underhood lights, TW driveshaft, Wet Okole seat covers, Dashlight mod, Many other little things to make the truck complete!
    Not if they are the older style? The older Camburg's won't correct your caster.
    To the OP you should look into "Icon" CO's. Better quality!
    But if you really want the RED CO's then look into Sway-A-Way from 4WP it's the exact same CO's just without the "logo". And they cost less!
  15. Mar 11, 2009 at 10:01 AM
    dud122
    Dan
    Riverdale Park, MD
    2002 Tacoma DC
    how do you know if they are the older ones?
  16. Mar 11, 2009 at 10:01 AM
    dud122
    Dan
    Riverdale Park, MD
    2002 Tacoma DC
    i could post pictures if you think you could tell by looking at them.
  17. Mar 11, 2009 at 10:08 AM
    dud122
    Dan
    Riverdale Park, MD
    2002 Tacoma DC
    i just asked the guy i bought them from... we'll see
    i'm going to neg rep myself if these are the wrong ones... i didn't even know to ask about that
  18. Mar 11, 2009 at 10:24 AM
    dud122
    Dan
    Riverdale Park, MD
    2002 Tacoma DC
    can someone tell me if these are the ones that would correct my caster after a lift??
  19. Mar 11, 2009 at 11:00 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hard for me to tell. Best thing would be to match them up to the originals.
  20. Mar 11, 2009 at 1:19 PM
    mr.trd
    mr.trd Are you Recreationally Insane?
    Brant
    Pocatello, Idaho
    '06 S/C 1GR-FE DCSB
    Icon coilovers w 14" 700lb springs, Icon billet UCA w/ Delta joints, custom built Icon rear resi-shocks, OME Dakar w/ AAL, superbumps up front and timbren bumps in the rear, Crown brake lines, U-bolt flip,4.88's with front ARB locker and ARB dual compressor mounted behind back seat, Original bronze 16x8 Konig Countersteer off-road wrapped in 285/75R16 GoodYear MT/R's, 2018 T4R TRD Off-Road 17x7.5 et 15 wheels with Spidertrax wheels spacers wrapped in 285/75R17 BFG KO2's, CBI Off-Road Fab. custom Trailmaster 2.0 with swing-away tire carrier, CBI custom tube front bumper, CBI kickout sliders, CBI Ditch Light brackets w/ Rigid D2's, FYRLYT's on the front, Leer used shell, OEM black chrome sport headlights, fog lights always on mod, rear locker anytime mod, TRD supercharger, Deatschwerks 255 fuel pump w/ URD external fuel filter kit, AFE intake paired to a Safari Snorkel, URD spec-U exhaust behind URD equal length headers.
    +1 on the Icon CO and if they are the wrong UCA's, sell them and get the Icon UCA's too. Then you know you have the best in both UCA's and CO's.
