Which weather proof rifle case for recovery gear?
Discussion in 'Recovery' started by Rujack, Aug 21, 2018.
  1. Aug 21, 2018 at 7:03 PM
    Rujack
    Rujack [OP] Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    Pelican, Plano or? I'm trying to shed some weight and I think I'm going to eliminate my chains that I've never used from the recovery gear I keep in a large ammo box. So I'll have a tow strap, tire repair stuff, small tool set of sockets and wrenches etc.
    Plano seems to be the most affordable, but curious to hear thoughts.....
  2. Aug 21, 2018 at 7:18 PM
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    I use Plano 42" ones, and have them on for just a few months. They're ok, as if no complaints. They keep my stuff dry, so I'm happy! I've seen a few guys around NE use them without any issues.
    Pelicans were/are out of my price range, but from whatever I've seen on another truck, they seem to be built "better", possibly thicker walls, and stronger hinges (guy had his recovery tracks bolted to the lid, opened the case and it stayed open without issues!)
    Good luck with your choice!
  3. Aug 21, 2018 at 7:26 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    I also use a Plano case. Works well. And cheaper than Pelican.
  4. Aug 21, 2018 at 7:29 PM
    Rujack
    Cool, thanks. I'm leaning Plano.
    Nice shower btw - I made a similar one.
  5. Aug 21, 2018 at 7:37 PM
    BuzzMor
    BuzzMor I Aim To Misbehave
    San Antonio, TX
    2007 Tacoma TRD Off Road - White
    Saving up money for the next one!
    Plano also. Hinges are a bit flimsy but it does have two locking hinges and a few spots where you can use an external lock. Comes in several dimensions
  6. Aug 29, 2018 at 5:05 PM
    Marbleyard
    Marbleyard Thread killer
    Virginia
    2019 4Runner Pro
    SOLD 2016 taco: premium technology and tow package. OV Tune 1.05; A.R.E. V Camper Shell; BRO grille & Tails; OEM bed mat; Xenon Depot HID headlight conversion; reflective gray tailgate letter inserts; GoPro session; Hondo radio knobs; K&N cold air intake, quicksand painted dash bezels, Subaru dash speakers, Kicker CS 6x9 fronts and 6.5 rear speakers; All LED interior lights and LED high-beam headlights. Redline elite hood shock props. prinsu cab and camper rack with rough country 30" light bar; (2) 8" rear facing “F.U.”rough country black LED lights; prinsu cargo basket kit, (2) prinsu load racks; roadshower 4; ARB 2500 awning and room kit; weather tech floor mats; carhart seat covers; ckma12 ARB air compressor under the hood; blue ridge overland gear air tools bag, tool bag, driver's seat molle. Rack mounted TRED 800 recovery treds and plano case. Rotopax water and fuelpax fuel canisters; Pelican cased first aid kit in bed. rockblokz mud flaps. ARB rear dif. breather. Stand alone fuse block. SSO bumper with 10k smittybilt synthetic line winch and factor55 ultrahook. Pro Eagle 2-Ton “The Beast” jack. OME lift kit: 90000 front shocks and 886 OME coils, Camburg 310078 UCA, 60091 rear shocks with light duty Dakar leafs. Good Year duratracs 285/75R16. Black vinyl inlays on factory OR wheels; RCI Steel Front/Trans/Trans Case/Rear Diff Skids, Alum A-Arm; Mobtown bolt-on sliders with scorpion bed coating; pelfreybilt aluminum fuel tank skid; Cali-Raised full length Molle storage LH & RH bed sides; Caliraised bedside reinforcements; HELLA sharptone horns; Optima blue-top battery with AJT machined red tiedown bracket. AJT quicksand key fob. Overland Bound member #6996
    My Plano buckled (buckled is a harsh word to explain it) in between my Prinsu bars, let VERY little amounts of water in. @Bastek looks to have a full flat surface to set the length of the case on to keep it from bowing. I will add flat plates or something under mine when I remount it later. I have it off and “flattening” back out and I’m sure it will be fine.
  7. Oct 8, 2018 at 7:44 AM
    Wedge
    Wedge Well-Known Member
    Yves
    Kebekistan
    17 OR DCSB MGM
    Bestop supertop Bronze Method roost 255/80/17 toyo open country RT Interior LED XenonPro HID low beam
  8. Oct 8, 2018 at 11:22 AM
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    i like monoprice. you can find them on sale once in a while. they do go out of stock often.
  9. Oct 30, 2018 at 10:10 AM
    lanceputnam
    lanceputnam Well-Known Member
    5.11 has theirs without foam for $99 on their website. Its made by SKB and appears to be of pretty good quality. Its the bigger size too which IMHO is the better choice. On my prinsu rack it looks much better than the shorter 1700 size rifle case.The only difference between it and my other pelican/storm cases is that the 5.11 does not have the latches on the ends. If you can live with that, the 5.11 box should work well. I'm still trying to figure out how I want to mount mine up there.
