Which welding class to take???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by utmck, Aug 13, 2011.
  1. Aug 13, 2011 at 1:41 PM
    utmck
    utmck [OP] Active Member
    I want to learn how to weld and have looked at the classes offered by the local college and I need some help in figuring out which class to take.
    Here is what they are offering:
    1. Intro to welding fundamentals
    2. Intro to shielded metal arc welding
    3. Intro to gas metal arc (MIG) welding
    4. Intro to gas tungston arc (TIG) welding
    5. Intro to pipe welding
    Thanks for your input.
  2. Aug 13, 2011 at 1:45 PM
    ksj
    ksj Well-Known Member
    Pacific NW
    2018 Cavalry Blue TRD Pro
    265/75-16 KO2
    1+4 IMO
  3. Aug 13, 2011 at 3:31 PM
    jasen7
    jasen7 Well-Known Member
    Jasen
    Jersey Shore Pa.
    2007 Tacoma 2.7l
    I think you should do all of them if it is possible. I have been welding since I was 12 years old and I am now 35. Trust me, knowing how to do every type of welding has major advantages! It also helps if you ever decide to take a job as a welder.
  4. Aug 13, 2011 at 3:34 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    :facepalm: why is this in the 2nd gen section :goingcrazy:
    what he said ^^^ the more qualified you are, the more marketable you are
  5. Aug 13, 2011 at 3:36 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Flagstaff, AZ/Walnut, CA
    2005 Tacoma Prerunner SR5 TRD offroad
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    1 and 3. I just took intro to welding at mt san antonio college and you learn how easy mig is.
  6. Aug 13, 2011 at 3:46 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    All if possible. But if funds are tight definitely take a TIG class. If you can TIG weld you should be able to MIG weld no problem.
  7. Aug 13, 2011 at 3:48 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    The 2nd Gens have welds in them... :cool:
  8. Aug 13, 2011 at 3:50 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    04 Tacoma 4x4, V6, 5spd
    Squattin'
    Take all of them, Im currently enrolled in a 2yr welding course to get a degree. Its taught me WAY more than I would have ever expected, I know people who only went one year and signed up for the last. Its well worth the time if your really interested in it.
  9. Aug 13, 2011 at 4:14 PM
    timsxr
    timsxr Well-Known Member
    portland
    second that!! great to learn it all i prefer tig but you cant use it for everything
  10. Aug 13, 2011 at 4:26 PM
    joes06tacoma
    Joe
    Central Coast, CA
    The class I took at our local community college was just titled "basic welding". Probably a cross between the first two that you have posted.
    I would start with #2. You'll spend a lot of time just laying down beads and learning how to work with the different type of rods.
    If you just want to learn how to weld on your own stuff, I don't see the need for a lot of "fundamentals".
    MIG is definitely easy once you learn to stick weld.
    If I ever take another class, I will take the TIG class.
  11. Aug 13, 2011 at 4:29 PM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Take all...
    I took all the class at my local CC. Learned a lot. Its good to know how to weld with oxy fuel, braze with mapp gas.
    Coming to tig from oxy fuel was REAL easy.
  12. Aug 13, 2011 at 9:31 PM
    5thToy
    5thToy Well-Known Member
    Thousand Oaks California
    09 Access Cab TRD OR
    Take as many classes as possible, with welding it seems the more you learn the more you earn.
    Also the more you learn the cooler the truck they give you.
  13. Aug 13, 2011 at 9:44 PM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    TIG and MIG are completely different.
    Are you able to choose which one you want to take. Usually they make you take them in order because of prereq. requirements
  14. Aug 14, 2011 at 5:22 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    I know they're different. But MIG is incredibly easy.
  15. Aug 14, 2011 at 5:44 AM
    jsutter
    jsutter Well-Known Member
    Jim
    Southeast Ohio
    08 Reg. Cab 4cyl 2wd
    cruise and intermittent wipers
    Agreed, most of the high strength steels now require TIG welding, plus you can do aluminum. Also, TIG welding is better for sheet metals; you will have a lot less warp and burn through because the gas draws some of the heat away.
    If you just want cheap for your home acetylene is nice, and you can always use a torch for loosening up/burning off stuck bolts.
  16. Aug 14, 2011 at 5:55 AM
    jasen7
    Jasen
    Jersey Shore Pa.
    2007 Tacoma 2.7l
    You can also weld aluminum with a MIG!
  17. Aug 14, 2011 at 6:18 AM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    They most likely won't let you jump ahead in the classes unless you can demonstrate you know what they would've taught you in them. I am not sure about Texas But in Cali we have RoP classes that would teach you all forms in one semester. If you can choose I'd go with mig as it is the cheapest, simplest welder that can give you pretty looking welds. Arc is good to know as you can do it on the trail with a pair of jumper cables, a battery and some sticks. Tig can weld almost anything, and produce the nicest welds. It is the most difficult of the 3, and the machine is the most expensive, with the average good machine running into the 3-5000 range.
  18. Aug 14, 2011 at 7:46 AM
    prerunner32
    prerunner32 TRD
    Alan
    Foothill Ranch
    05 Prerunner TRD Sport Longbed
    285/70/17 BFG A/T's, 17in Method Double Standard Wheels, Camburg 2.5 Coilovers, Alpine Head Unit, Infinity Speakers, 10" JL Audio Sub, 2 Rockford Fosgate Amps, AFe Stage 2 Si (Oiled)
    If im not mistaken, since its a college, you probably have to take one after the other ect... I know thats how my college was with welding. Im saying that because not just anyone can just jump in and start TIG and pipe welding. Those types of welding are the hardest types of welding out there. You would need skills first. So just start with #1 and work to #5 and you will be set :)
  19. Aug 14, 2011 at 7:52 AM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    no offense but i hope you dont plan to make a career out of it, stainless tig, and pipe welding though, at least pipe welding you'll learn a little something about a real trade, fitting pipe.
    a welder is just another tool in a fitters tool box, as they say....
  20. Aug 14, 2011 at 5:56 PM
    Erll
    Erll Well-Known Member
    My Name is Erll
    Des Moines, Iowa
    Speedway Blue
    Check my sig
    1 and 4
