Which wire do I cut?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Fade to black, Apr 18, 2017.
  1. Apr 18, 2017 at 12:00 PM
    #41
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Drain your transmission fluid and pour it in your radiator. Eventually your transmission will stop shifting.
    PottMatter and Lakeboy like this.
  2. Apr 18, 2017 at 12:02 PM
    #42
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    Every wire cut results ...
    ShamwowTaco and BYJOSHCOOK like this.
  3. Apr 18, 2017 at 12:03 PM
    #43
    Colton58D
    Colton58D Well-Known Member
    2017 Tacoma Trd Pro
    I told you not to ask. Now everyone will know. Gah!!!
  4. Apr 18, 2017 at 12:05 PM
    #44
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
  5. Apr 18, 2017 at 12:09 PM
    #45
    CHarrison32
    CHarrison32 Well-Known Member
    Cody
    West Virginia
    2011 AC 4x4
    Bilstein 5100 all the way around, wheelers 3-leaf progressive AAL, Camburg Ball-joint UCAs, SCS SR8, BFG KO2 20% tint, WeatherTech floor mats, Tacoma bed mat, tonneau cover
  6. Apr 18, 2017 at 12:11 PM
    #46
    Colton58D
    2017 Tacoma Trd Pro
  7. Apr 18, 2017 at 12:13 PM
    #47
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Ok here is what you do fade.. first you need to locate the GPS tracking device in the truck. It's either above the headliner or under the dash. Cut that guy out of there and then you can modify the transmission harness any way you like and the dealer won't know..
    Fade to black[OP] likes this.
  8. Apr 18, 2017 at 12:22 PM
    #48
    9TRDTCO
    9TRDTCO Well-Known Member
    Is the OP your friend??
    smitty99[QUOTED] likes this.
  9. Apr 18, 2017 at 12:24 PM
    #49
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Smitty is everyones friend
    PottMatter, bobrown14, nDub and 2 others like this.
  10. Apr 18, 2017 at 12:25 PM
    #50
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Where is op? I'm on my lunch break and I want to see how this turns out
    9TRDTCO and smitty99 like this.
  11. Apr 18, 2017 at 12:26 PM
    #51
    Benzdriver81
    Benzdriver81 Making it fool-proof will just make a better fool
    Kevin
    PNW
    05 DCLB Sport
  12. Apr 18, 2017 at 12:34 PM
    #52
    ShamwowTaco
    ShamwowTaco 'Murica
    2006 DCSB TRD OR
    Stickers, plastidip, and light bar.
    GI Joe taught me everything I know in this life.
    PottMatter and 9TRDTCO[QUOTED] like this.
  13. Apr 18, 2017 at 12:36 PM
    #53
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    OP this thread needs your help! Please give us more !
  14. Apr 18, 2017 at 12:41 PM
    #54
    TeecoTaco
    SW Ontario
  15. Apr 18, 2017 at 12:42 PM
    #55
    cmack
    cmack Well-Known Member
    18 Burrito
    gotta cut the fuel line if it's a turdgen
  16. Apr 18, 2017 at 12:48 PM
    #56
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    bobrown14 and smitty99 like this.
  17. Apr 18, 2017 at 1:02 PM
    #57
    BananaPeelOut
    BananaPeelOut Well-Known Member
    Ben
    NH
    2005 silver access cab TRD Off-Road
    Kenwood Headunit, CB radio setup, wind deflectors.
    Good reference
    markm0311[QUOTED] likes this.
  18. Apr 18, 2017 at 2:04 PM
    #58
    Benzdriver81
    Kevin
    PNW
    05 DCLB Sport
    Second independent verification:
    This is now scientific law.
    Wait, that's G.I. Joe??? I thought that was a cartoon Magnum P.I. :notsure:
  19. Apr 18, 2017 at 6:51 PM
    #59
    Fade to black
    Fade to black [OP] New Member
    2016 Tacoma Black TRD Sport
    Umbrella tinted front windows
    The Throttle Position (TP) sensor is located on the throttle body of a fuel injected engine. This type of sensor is known as a potentiometer. A variable resister used to control voltage in a circuit. The TP sensor is used to detect engine load. Its output is shared by the PCM and the TCM. This sensor's input signal along with the vehicle speed sensor are used by the TCM to provide optimal shift timing.
    Most TP sensors have extra pins for extra internal functionality, but for this discussion we look at three terminals and this sensors relation to automatic transmission performance. This is because a faulty TP sensor will cause erratic shift timing and affect torque converter engagement.
    One lead is connected directly to the computer's 5-volt reference voltage supply. The opposite end of this internal resistance strip is connected to ground. Another is connected to the PCM. This wire is connected to the movable arm that swipes across an internal resistance strip sending a varying voltage signal back to the PCM. This signal indicates the engine's throttle angle. This is called the signal circuit of the sensor, because it's the lead the sends the varying voltage signal to the controller indicating the changes in throttle angle.
    The sensor is attached to the throttle plate shaft and changes output voltage as the throttle plate opens and closes. The output voltage will be low or around 0.45 volts if the throttle is closed and will be high or 4.5 volts at (WOT) Wide Open Throttle. The fuel injection and ignition timing are adjusted by the PCM as the throttle plate and TP sensor are moved. If the driver suddenly accelerates their vehicle, the PCM would receive this 4.5 volt signal and increase the fuel injection timing to compensate. This would also indicate to the TCM that a downshift is needed.
    What I think is that toyota has given our trucks a bad TP sensors and can live without a recall due to the trucks still shift.just not the way we would like or are used too.
  20. Apr 18, 2017 at 6:59 PM
    #60
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    There is no separate tps on our trucks fade. It is built into the electronic throttle body assembly. The tp sensors in your write-up with a low of .5 volts and a hi of 4.5 volts are on the 1st gen throttle cable systems.
