which y-pipe works best
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ElFlacoTaco07, Mar 8, 2013.
  1. Mar 8, 2013 at 8:28 AM
    ElFlacoTaco07
    ElFlacoTaco07 [OP] Member
    Alex
    Arizona
    '12 TRD
    FLowmaster Dual Exhaust #17432
    so i been reading and reading and READING but some of the post are maybe 2-4 years old and a few ppl have complains about the DTLH and others going with the URD Y-pipe but i would assume by now DT would got smart enough to made adjustments so i dont have to cut anything. seeing how my truck is a 2012 notice that the DTLH have were u can put the O2 sensors back in same with their y-pipe, would appreciate the feedback if anyone has installed either one with the DTLH and which makes the less rattling noise cause heard that was one of the biggest upsets from the y-pipe from DT
    http://urdusa.com/Exhaust-&-Headers..."Pipe-Bomb"-Y-Pipe-2005+-V6/product_info.html
    http://urdusa.com/Exhaust-&-Headers...ipe-for-4WD-Tacoma-V6-2005+/product_info.html
    those r the y-pipes im talking about, and if with either one ill need that O2 simulator.
  2. May 17, 2013 at 6:54 AM
    KingKoda
    KingKoda Never Satisfied
    Palmetto
    '12 TRD.S DCSB 4x4
    Boosted TRD/URD All Terrain Sleeper w/ Sockmonkey Decals Worth +666HP
    I'm interested in both of these as well. From what I read at those links you do not need an O2 sim. The URD pipe also has connections for that.
    "The URD Competition Y Pipe does include ports for the rear O2 sensors. It will not cause a check engine light from elimination of the rear catalytic converters. On the 1GR-FE engine the rear O2 sensors are installed between the front and rear catalytic converters and they only monitor the health of the front set of catalytic converters. You will not need a rear O2 simulator to run this competition Y pipe."
    I'm interested if I would gain any performance from them being s/c'd. Also, if they improve clearance. The stock pipe hangs low and looks to be the first thing I would destroy underneath. I don't have emissions tests in my state so not too worried about that.
