Which
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BlueBeard, Oct 20, 2024.
  1. Oct 20, 2024 at 2:35 PM
    BlueBeard
    BlueBeard [OP] New Member
    I have been trying to figure out an issue.
    dash lights (the illumination for RPM and Speed and only daytime) do not seem to be working. I checked the fuses, but I wasn't sure which ones to look at. Any help would be appreciated
  2. Oct 24, 2024 at 5:26 AM
    Tacorific
    Tacorific Well-Known Member
    NE Iowa
    Barcelona Red 2018 SR5 I4 4X4
    Torque Pro, LED Map & Dome lights, Westin Hitch, Ride Rite Air bags with Daystar perches, Utility Package Rear Cab Panel
    Have you inadvertently turned down your dash lights dimming control?
    memario1214 and pltommyo like this.
  3. Oct 24, 2024 at 5:34 AM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Are you saying your gauges aren’t lit during the day? I’m asking because I’m not sure what “only daytime” means.
    Chew likes this.
  4. Oct 24, 2024 at 6:18 AM
    Taxx
    Taxx Well-Known Member
    Should be a listing of the fuses on the back of the fuse box cover. There are two fuse boxes, one under the dash on drivers side and one under hood on drivers side.
  5. Oct 24, 2024 at 7:45 PM
    Cushmaat
    Cushmaat Well-known wiseass.
    SE AZ
    2022 TRD OR 4x4 DCLB MGM
    Do you have something covering the photosensor on the dash (I.e. a piece of paper, hat, etc)?
  6. Oct 24, 2024 at 7:48 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Can you make it get brighter by turning the headlights on/off? If yes check the rheostat (dimmer switch)
