While I'm at it, should I do more?
Discussion in '1st Gen. Tacomas (1995-2004)' started by manapiko, Jul 12, 2022.
  1. Jul 12, 2022 at 4:30 PM
    manapiko
    manapiko [OP] Well-Known Member
    Patrick
    Lynnwood, WA
    2003 Tacoma TRD
    Good afternoon all!
    I'm about to do some needed maintenance on my 03 4x4. Here's what's on the list:
    1. New rotors and pads up front
    2. New shoes and drums out back (both front and rear are slightly warped)
    3. Replacing valve cover gaskets and plugs (both sides are seeping)
    4. Replacing carrier bearing
    5. Full fluids flush and replacement
    Anything that I might as well replace?
    This is a second vehicle for us, sees driving duty about 3x week for 50 miles or less. Will get some fun off-road action about twice a year.
  2. Jul 12, 2022 at 4:32 PM
    YotaGangYotaGang
    YotaGangYotaGang PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
  3. Jul 12, 2022 at 4:37 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    While your doing a brake overhaul you might think of also doing the rubber brake hoses.
    always remove your fill plugs before draining anything.
    drizzoh and Key-Rei like this.
  4. Jul 12, 2022 at 4:46 PM
    jw_96taco
    jw_96taco Everything is broken
    Jamie
    Chattanooga, TN
    1996 Tacoma 4x4 5spd Manual
    ARB Front Bumper Smitybilt Winch Crappy Paint Job
    While you have your valve cover off you should at least check the valve clearances. I know they like to go out of alignment, wouldn't hurt to check.
  5. Jul 12, 2022 at 6:02 PM
    Old green toyota
    Old green toyota Well-Known Member
    Sacramento,CA
    99 2.7 4x4 Standard cab
    Oil leaks
    What's the mileage?
    Something simple I'd add is greasing every moving part. Tailgate mechanisms, door latches, hinges, hood latch etc.
  6. Jul 12, 2022 at 10:52 PM
    Just_Tombo
    Just_Tombo Well-Known Member
    2003 prerunner TRD DC 3.4
    For not much more than the price of rotors and brake pads, you could buy the Powerstop tundra brake upgrade and hardline conversion. I just made this decision as like you, my rotors were warped (pretty common on these trucks, from my research)
    I also just did my valve covers for the same reason - and when I did the work, I just have upset leak the juju in the old vacuum hoses, because I had a vacuum leak after I got it all buttoned up. New silicone hoses did the trick. I also replaced the pcv valve, grommet, and hose (OEM, because the silicone will not tolerate the oil/fuel contact for long)
  7. Jul 13, 2022 at 2:04 AM
    Jakuku Pahwheenis
    Jakuku Pahwheenis i provide useless forum contributions
    J Phoenix
    South Carolina
    2003 Xtracab 2.7L 3RZ-FE 4x4 manual 245K+ miles
    I second this. Just did mine a few weeks ago. Found valves as much as .oo5 out of spec, adjustment made a 36 psi difference in cylinder compression.
  8. Jul 13, 2022 at 8:15 AM
    manapiko
    Patrick
    Lynnwood, WA
    2003 Tacoma TRD
    Beauty, thanks!
    Absolutely looking into this upgrade. Trying to find a complete kit out there right now.
    When you did the hoses, did you piece it together or get a kit?
    I'm a few thousand away from 200k. I like this advice and I'll do this myself too.
  9. Jul 13, 2022 at 9:08 AM
    Just_Tombo
    Lots of good info here, and you can buy the hard line kit from a link on page
    https://adventuretaco.com/guide/step-by-step-tundra-brake-upgrade-on-a-tacoma-or-4runner/
    I bought the hard line kit from adventure taco, which you will find in the write up, and followed his instructions. He is a member here, can't recall his handle, maybe r someone will chime in.
    This is the tundra upgrade kit I bought: calipers, rotors and pads. Debated for a long time about getting OEM, parts, but I found enough evidence that people are happy with this upgrade and decided to save the money. Power Stop KC2324-36 Z36 Truck & Tow Front Caliper Kit-Drilled/Slotted Brake Rotors, Carbon-Fiber Ceramic Brake Pads, Calipers https://www.amazon.com/dp/B00KT5E9IA
    Good luck!
  10. Jul 13, 2022 at 9:10 AM
    ToyoTaco25
    ToyoTaco25 Well-Known Member
    North Carolina
    09 Super-White DCSB 6-Speed
    ProComp 4" D-Bag, I mean Drop Bracket Lift, AMP Research Powersteps, 285/70-R17’s, Magnaflow, AFE CAI, Dipped Badges
    U-Joints since you're doing carrier bearing.
  11. Jul 13, 2022 at 12:56 PM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    Grease the zerks on the driveshaft, will be easier with the driveshaft hanging.
    Nessal likes this.
  12. Jul 13, 2022 at 3:43 PM
    Morden
    Morden Well-Known Member
    Cali Central Valley
    2002 Tacoma TRD PreRunner
    Transmission mount.
    Alternator brushes and possibly check the bearings in there as well.
    Diff fluid.
    Don't know if you have a MT or AT, but if the latter change out the AT filter.
    Radiator, hoses & all belts.
    Flush power steering fluid & clean the reservoir screen.
