Whine at 55 mph
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nh_yota, Sep 6, 2016.
  1. Sep 6, 2016 at 1:23 PM
    nh_yota
    nh_yota [OP] Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    2" Lift with HS coils/AAL and 5100s, TRD Exhaust, TRD Skid Plate, URD Short Shift, AT3s
    No it's not from the wife or kids.
    Last month I started noticing a faint whine that's really only audible over normal road and tire noise between about 50 and 55 mph. It's loud enough to notice on the highway while the radio is set at a medium volume, at least for a trained ear. I'm hoping it's just harmonics from the tires wearing and changing their pitch but it's got me worried that the truck is developing an issue with the differentials.
    It's a 2010 DC OR V6 with the 6-speed manual and just over 78k miles. I replaced both front wheel bearings last fall at ~65k miles and all of the gear oils last winter. I've determined that the whine is coming from the drivetrain or the wheels because it's not related to engine speed or clutch/neutral/accelerating/coasting etc. I can't tell if it's coming from the front or back.
    The sound is more of a whine and not a groan or a squeal so I'm leaning towards tire noise, which is fine if that's the case. I've never heard the sound of bad bearings or diffs so I don't have anything to reference.
    Thoughts?
  2. Sep 6, 2016 at 1:49 PM
    sivart7208
    sivart7208 Well-Known Member
    NH
    18 DCLB TRD Off Road
    I had the same sound coming from the rear.. had to replace bearings in rear differential..
  3. Sep 6, 2016 at 2:02 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Do you have a go-pro or similar kind of camera that you can mount under your truck and drive around while recording? Do it with the camera facing the front and the rear, might help determine where it's coming from and what it is
  4. Sep 7, 2016 at 10:12 AM
    nh_yota
    Jeff
    Portsmouth, NH
    I hope not. I've already had enough things repaired in this truck.
  5. Nov 1, 2016 at 12:56 PM
    Onuspdander
    Onuspdander New Member
    2009 Tacoma
    TRD Exhaust
    I am having the same problem with my 2009 Tacoma. Just put on new Michelin tires and I am notiving a signifigant whine between 55 and 60 mph. It goes away after that. Come back again around 35 to 40 mph. Hope it is the tires. Any way to check this out?
  6. Nov 1, 2016 at 1:00 PM
    Clearwater Bill
    Billy
    Largo Florida
    Borrow a set of tires from a friend for a test drive.
    Michs are well warrantied. I'd be surprised if they didn't take care of that for you, assuming you determine they are the source.
    It could be the new tires are so quiet you now hear another noise that was masked before.
  7. Nov 1, 2016 at 1:05 PM
    Clearwater Bill
    Billy
    Largo Florida
    When was the trans fluid last changed? And with what?
    If you don't know, changing it, even if you are just base lining your maintenance, is a good idea. And it could help your whine if it's from the box.
    Toddle down to your Ford dealer and pick up Ford XT-M5-QS fluid. It's not cheap, but it is awesome.
  8. Nov 1, 2016 at 1:06 PM
    wyotacotrd
    wyotacotrd Well-Known Member
    Cade
    Laradise, Wy
    White 2012 DCSB TRD Offroad v6
    Fox 2.5 Remote Resevoir Coilovers, SCS Ray10 bronze, IVD progressive AAL, Fox 2.0 Remote Resevoir rears, Wheelers OR bump stops, Prinsu design studio cabrac, Softtop in Tan, etc...
    Did someone secretly install a supercharger while you weren't looking?
  9. Nov 1, 2016 at 6:20 PM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    My '14 Sport rear diff has howled from the day that I got it, Toyota refuses to acknowledge that it's an issue. They changed diff suppliers in 13ish because of this issue and they refuse to acknowledge that the problem still exists.
    At exactly 60 mph it quiets down, and as soon as I feed it gas to load the pinion, it quiets down. Not what I expect out of a $35,000 truck. There's a TSB on this prior to '14 but not for mine.
  10. Nov 1, 2016 at 6:34 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Wheel bearing is my guess.... that happened to me, only made noise at about 50mph and only when I gave it gas
  11. Nov 2, 2016 at 7:31 AM
    beetlevegas
    beetlevegas You are no Vader. You are just a child in a mask!
    JP
    Las Vegas NV
    2011 silver Tacoma TRD 6 Speed double cab
    stuff
    I had the same problem. Looked it up at work and there is open TSIB on it for 5 speeds. My truck is a 6 speed, My problem was I need to replace the front pinion bearing. One of my techs was able to get it out with out having to tear apart my rear end.
  12. Nov 2, 2016 at 8:26 AM
    10trdtaco
    10trdtaco American Infidel *DON'T TREAD ON ME*
    Shayne
    Lynchburg, VA
    2010 Tacoma TRD Sport DCSB
    4" lift 33-12.50-17 Atturo Trail Blade M/T 17" HELO TRD Satoshi Blackout Grill Tinted headlights with caliraised led headlights ... More to come
    Check wheel bearings first, notorious to go bad... had some of the same symptoms!
  13. Nov 2, 2016 at 3:30 PM
    hotrod53
    Lynd
    Pittsburgh, PA
    If it is a front beating, try this. While driving at speed and going straight, turn very slightly right, then slightly left, just enough to load the wheel bearing. If either makes the noise go away, it's the front wheel bearing. If you turn slight right and it goes away, it's typically the left wheel and vice versa.
