Whine coming from engine bay when RPM's go up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by paskanaama, Mar 4, 2017.
  1. Mar 4, 2017 at 4:23 PM
    paskanaama
    paskanaama [OP] Well-Known Member
    2006 SR5 Tacoma Manual
    When I accelerate in my Tacoma, there is a whine that comes from my engine bay, and increases with whining. It is not putting up a check engine light at all, and got my pulleys checked out and they seem to be fine. Any other ideas what it could be?
  2. Mar 4, 2017 at 4:30 PM
    Murdered Out Tacoma
    Murdered Out Tacoma NightRunner
    Socal (IE)
    Black 06 DCLB Sport
  3. Mar 4, 2017 at 4:35 PM
    adamax
    adamax Well-Known Member
    adam
    springville ut
    2015 trd off road
    supercharger?:burnrubber:
    PNW BlueReaper and LuckyToy like this.
  4. Mar 4, 2017 at 4:36 PM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    Could still be a pulley.
    I just changed the idler closest to the alternator. I was barely able to tell the pulley was bad. Even when I pulled it and spun it, I wasn't 100% sure. It felt almost as good as the new one. Noise gone, though.
  5. Mar 4, 2017 at 4:38 PM
    paskanaama
    That's what I was thinking, but the voltage for my alternator is fine. According to my CPU
  6. Mar 4, 2017 at 4:38 PM
    paskanaama
    Ok. How could you explain the sound you had?
  7. Mar 4, 2017 at 4:39 PM
    Murdered Out Tacoma
    Socal (IE)
    Black 06 DCLB Sport
    My alternator whinned for about 2 days before it completely went out on me on the freeway to work. It sounded like a hand cranking generator sound, if you ever used one.... My gauges suddenly stopped working and stock radio would cut out every couple seconds.
  8. Mar 4, 2017 at 4:40 PM
    js312
    Joe
    New England
    A whine that got louder with engine RPM. Sounded like I had a supercharger. Was worse in warm weather, oddly enough. Started around 111k, drove on it for 3k until I had a warm day where I felt like dealing with it.
  9. Mar 4, 2017 at 4:49 PM
    paskanaama
    Did the pitch of the whine ever change for you? I would say minthat sounds the same, but once in a while the pitch will become a lot higher
  10. Mar 4, 2017 at 4:49 PM
    paskanaama
    It happens with, and without AC on
  11. Mar 4, 2017 at 4:52 PM
    js312
    Joe
    New England
    If anything, it may have gotten higher pitched at higher RPM, but I think it generally stayed about the same.
  12. Mar 4, 2017 at 4:52 PM
    10MGM
    10MGM Well-Known Member
    2010 AC MGM 4x4
    Steering pump?
  13. Mar 4, 2017 at 5:01 PM
    paskanaama
    This was also a thought I had, but wouldn't that make odd sounds while turning the wheel? This has been happening for about 10 months, so if it was that I would suspect it would crap out already
  14. Mar 4, 2017 at 5:01 PM
    paskanaama
    Ok. When I have the ambition I will take another look at my pulleys
  15. Mar 4, 2017 at 5:05 PM
    10MGM
    2010 AC MGM 4x4
    Worn steering pump makes most noise a full lock.
  16. Mar 4, 2017 at 9:04 PM
    PNW BlueReaper
    PNW BlueReaper Slowly but Surely
    Aaron
    Kent, WA
    05 DCSB Indigo Ink Tacoma
    Was hoping someone installed a supercharger for you, just because. But when does that ever happen.
