Whine coming from the engine bay
Discussion in '2nd Gen. Tacomas (2005-2015)' started by paskanaama, Jul 18, 2016.
  1. Jul 18, 2016 at 8:30 AM
    paskanaama
    paskanaama [OP] Well-Known Member
    2006 SR5 Tacoma Manual
    I have had a loud whine after my truck gets warm. I had this happen, and my serpentine belt busted, because of a worn out pulley. After that happened, I had to have the shop fix it, and I said that there are 3 bad pulleys. I felt around and felt 3 pulleys wobbling. The mechanic said that only the one was bad. After I had that one replaced, the whine was gone for a few hours, and then back again.
    I thought maybe it was the transmission letting me know I need a flush, but if I rev in neutral, the whine is there.
    I am going to have a mechanic find the exact area that the whine is coming from, but I would like to see if I could get some opinions here first. My truck is a 2006 Tacoma sr5 V6 4.0L manual.
  2. Jul 18, 2016 at 8:35 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Keep changing out the pulleys until the whine is gone; that's what I did. Check your new belt for signs of abrasion. My belt still looks like new after 1k, thank God. Good luck; you'll figure it out.
  3. Jul 18, 2016 at 8:39 AM
    paskanaama
    The luck is needed! I've had this truck for 4 months, and love it, but hate it at the same time. Almost seems like a lemon. But I will most definitely do that! Thanks a lot
  4. Jul 18, 2016 at 8:43 AM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Whine under the hood? I have seen guys prank each other by putting various stinky or noisy things under a hood. Check to see if somebody put the 3rd Gen Forum under there.
    hyper15125, CurtB, Harry and 5 others like this.
  5. Jul 18, 2016 at 8:43 AM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    Sorry...couldn't help myself.
  6. Jul 18, 2016 at 8:44 AM
    paskanaama
    Haha, it's all good. A little humor is always welcome!
    steelhd[QUOTED] likes this.
  7. Jul 18, 2016 at 8:49 AM
    paskanaama
    At what KM/Miles did you pulleys start whining?
  8. Jul 18, 2016 at 8:53 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    They started making noise around 90k miles; truck has 129,000, now. You should have changed the $30 tensioner pulley BEFORE it exploded and you had to buy the whole $100 tensioner; you learned something and that's a good thing.
    When the truck is idling with the headlights on and you rev the engine do the headlights "flare' or get brighter? That could be a sign of the alternator going south.
    wilcam47 likes this.
  9. Jul 18, 2016 at 8:54 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The whine does not go away when you push the clutch down does it?
  10. Jul 18, 2016 at 8:56 AM
    paskanaama
    yes it does. At idle I cannot hear the whine. It goes with the rpms.
  11. Jul 18, 2016 at 8:58 AM
    paskanaama
    Hmmm. I'm not exactly sure. I will have a look at that tonight. Would that create the whine though? And even if my lights do that, couldn't that still be because the serpentine belt isn't spinning as easily as it should be?
  12. Jul 18, 2016 at 8:59 AM
    paskanaama
    actually it was an idler pulley. The pulley was $90 CAD, but also a belt. Still taught me something.
  13. Jul 18, 2016 at 9:03 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    So they didn't change out the BELT TENSIONER pulley? I'd change it to save a bigger headache possibly sooner rather than later. They did an idler, that's good but keep an eye on the belt for abrasion.
  14. Jul 18, 2016 at 9:04 AM
    paskanaama
    That's what I said as well. But they claimed it would be a wast of money and time because the rest are perfectly fine. Must have been very lazy
  15. Jul 18, 2016 at 9:06 AM
    paskanaama
    I was willing to have them change all 3 idle pulleys and the tensioner pulley. Especially while they were already in there. As soon as I heard that whine coming back, I was angered greatly.
  16. Jul 18, 2016 at 9:07 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    This is why you learn to do it yourself. It's a real heart pounder when you've disabled your own truck but take a breath and you can do it (if I can do it, you can do it.... trust me)
  17. Jul 18, 2016 at 9:11 AM
    paskanaama
    I can do some things myself, but when I break down 3.5 hours from where I am supposed to be, I can't really help it. But I know that if I get a local mechanic to do it, it will be different. They knew I was from out of town. I enjoy (sometimes) working on my vehicle, but I don't have the time, or the space to do it anymore.
  18. Jul 18, 2016 at 9:12 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    I know the feeling. Talk to your local Fire Chief and find out who he uses for auto repair.
  19. Jul 18, 2016 at 9:14 AM
    paskanaama
    Yeah, moving across country is hard. But I will eventually have all of the things necessary again! Then, I don't have to get ripped off anymore
  20. Jul 18, 2016 at 10:22 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If it happens as soon as you depress the clutch then you may have a throw out bearing issue related to the manual transmission. How many miles do you have on this Beast?
