Whine coming from the engine bay
Discussion in '2nd Gen. Tacomas (2005-2015)' started by paskanaama, Jul 18, 2016.
  1. Jul 18, 2016 at 10:27 AM
    paskanaama
    paskanaama [OP] Well-Known Member
    2006 SR5 Tacoma Manual
    Nah, the clutch is solid. It starts as the engine warms up, and when the rpms go up. I have tried in neutral and it whines. But the truck has 137k km. Just about 85k miles
  2. Jul 18, 2016 at 10:34 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Power steering fluid low? if its with clutch related one of the fingers on clutch could be warped and catching wind making a whistling sound... if its engine its best to narrow it down to a certain spot or component.
  3. Jul 18, 2016 at 10:43 AM
    paskanaama
    all fluids are good. I'm 100% certain the clutch has nothing to do with it. If you would just read some of my replies, it whines even in neutral.
  4. Jul 18, 2016 at 10:45 AM
    wilcam47
    Will
    Bourbon state
    Fluids can still be good on powersteering and bearings going out can cause the whine.
    12TRDTacoma likes this.
  5. Jul 18, 2016 at 10:47 AM
    paskanaama
    Yeah, that's my main concern. I am positive there is a bearing in one of the pulleys going. Could be any of them. Sounds like it is on the driver side, so either tensioner, or power steering is my conclusions so far.
  6. Jul 18, 2016 at 10:48 AM
    wilcam47
    Will
    Bourbon state
    dont forget about a/c clutch.
  7. Jul 18, 2016 at 10:50 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    You probably have a super charger and didn't know it
  8. Jul 18, 2016 at 10:54 AM
    paskanaama
    I wish
  9. Jul 18, 2016 at 10:54 AM
    paskanaama
    thanks
  10. Jul 18, 2016 at 11:30 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Here's a good test performed using a simple long flat blade screwdriver or a stethoscope if you have one readily available. Take the end of the blade on the screwdriver and put it close to the pulleys in question. If you hear the noise amplifies through the handle of the screwdriver then you just found your bad bearing or pulley.
  11. Jul 18, 2016 at 11:33 AM
    paskanaama
    thanks. I am getting my transmission flushed, so I will ask them to check that out when I go in
    12TRDTacoma[QUOTED] likes this.
  12. Jul 18, 2016 at 2:23 PM
    eon_blue
    Azusa, CA
    How about a clicking sound instead of a whine? I have this "ticking", almost like a cricket chirping, that is only really present when I'm coasting in gear. As soon as I touch the clutch pedal, even just slightly, the ticking/chirping ceases. Comes right back when I let off the clutch. Throwout bearing? :notsure:
    :threadjacked: :sorry:
  13. Jul 18, 2016 at 5:39 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'm sorry to say it, but throwout bearing. Remove the transmission and replace what you need to and what you should while you are in there. The noise will receed.
  14. Jul 18, 2016 at 5:47 PM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    LMAO
  15. Jul 18, 2016 at 5:48 PM
    #35
    hyper15125
    NJ (609)
    Username: likes this.
  16. Jul 18, 2016 at 5:52 PM
    #36
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    OP - I recently had a similar "whine" and it was an idler pulley. Toyota replaced 2 of them (per their recommendation) as well as some plate under my extended warranty, even though only one of them was bad. Since they had it all apart, I also bought a new Serpentine belt....no labor charge for installation.
  17. Jul 18, 2016 at 5:54 PM
    #37
    paskanaama
    I have a fairly new serpentine belt, but most definitely need a new pulley. Thanks for the reassurance
