whine from engine when cold
Discussion in 'Technical Chat' started by porkchophill, Nov 12, 2014.
  1. Nov 12, 2014 at 1:05 PM
    porkchophill
    porkchophill [OP] New Member
    Walleyworld, CT
    SR5
    I just purchased a brand new 2015 SR5 quad cab V6 Auto and love it. But the 3rd day I had it I started it up and had to run back in the house quickly for something. Came back out within 40 seconds and at idle it almost sounds like a PS pump whine as low on fluid. Fluids all great and it will make this whine until it runs for about 5+ minutes. I figured let me drive it a bit to see if it was break-in related but with 2000 miles on the clock it still does it. Any ideas on this one before I take it in to Toyota?? When I turn the sterring wheel there is no change in pitch. So its either the clutch fan, and idler pulley bearing or maybe it is the PS pump. Thoughts?
  2. Nov 18, 2014 at 11:04 PM
    BCTSR5
    BCTSR5 NorthernTacoShop.com
    Vancouver
    2020 Taco TRD Sport
    air injection pump?
  3. Nov 18, 2014 at 11:24 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    cold belt + stiff grease in pulley bearings perhaps?
