Whine/squeek/weird noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 08pretaco, Oct 12, 2010.
  1. Oct 12, 2010 at 6:12 PM
    08pretaco
    08pretaco [OP] IG @14burrito
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Ended up wheeling in some sand a couple weeks back and ever since I have a whine/squeeky noise coming from underneath the truck. Happens in forward and reverse. It does not sound like its coming from the front rather than directly underneath or behind me with the window down.
    On the trip we were in some sand and I had a very tough time getting traction on a "take-off" and the axle was hopping everywhere...could that have something to do with it? Where should I start to look? :confused:
  2. Oct 12, 2010 at 6:14 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    lube the u joints and check the carrier bearing.
  3. Oct 12, 2010 at 6:14 PM
    Coreyjon
    Coreyjon Northern Alliance: Airlift Div
    Upstate, Ny
    08 DCab 4X4 SR5 TRD Sport
    iPod Adapter, Bilstein 5100's @ 1.75" front, Wheelers 3-leaf 1.5" + overload rear (2"), custom carrier bearing drop spacers.
    does it change pitch/sound with clutch actuation?
  4. Oct 12, 2010 at 6:15 PM
    08pretaco
    Oliver
    az
    Cant lube u joints they are sealed but near the end of the month i will be replacing them with greasable sets...carrier bearing *is (not looks) tight and no debri or anything that i can see around it
  5. Oct 12, 2010 at 6:16 PM
    08pretaco
    Oliver
    az
    No it does not. Sounds the exact same until I cant hear it anymore either from the truck being to loud of the sound goes away.
  6. Oct 12, 2010 at 6:18 PM
    Coreyjon
    Upstate, Ny
    so the noise is only occurring while truck is in motion (forward/reverse) not while sitting still with engine running. So its a part that turns when the vehicle moves, carrier bearing/driveshaft more likely than TO bearing (release bearing) from the sounds of it....(no pun intended). Hopefully we can narrow this down.
  7. Oct 12, 2010 at 6:18 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    hmm, not sure then. maybe wheel bearing?
  8. Oct 12, 2010 at 6:21 PM
    Coreyjon
    Upstate, Ny
    he says it sounds like its coming from behind him, pretty much most likely culprit is a bearing, now its a find the bearing hunt!
  9. Oct 12, 2010 at 6:22 PM
    08pretaco
    Oliver
    az
    Maybe. I actually just went out to look at it and the UCA uniballs are extremely dry with a glob of dirt/dust just sitting on top of them. I will go hunt my teflon grease down and clean and spray tomorrow and see if that does anything. Other than that I have done a great visual inspection of the driveshaft and everything along with that area. Otherwise IDK I hope it is not a wheel bearing lol
    EDIT: It does sound like its behind but I consider myself legally deaf lol
  10. Oct 12, 2010 at 6:25 PM
    Coreyjon
    Upstate, Ny
    So, the noise is always happening when the vehicle is rolling. is there any vibration associated with it, or just the noise, does it start the moment you start rolling forward or does it take some speed, does it change pitch as you increase speed until you can no longer hear it do to wind/road/engine noise?
  11. Oct 12, 2010 at 6:26 PM
    Coreyjon
    Upstate, Ny
    hmm, well obviously not deaf enough if you can still hear it whine/squeak...
    Corrective action: Listen to loud music until squeaking stops..:D
  12. Oct 12, 2010 at 6:28 PM
    08pretaco
    Oliver
    az
    It starts the second trucks in motion. I cannot tell if the noise changes in any way because it either stops while I get moving quicker or the road noise and exhaust drone it out. I am unable to hear it very early in acceleration if not once the truck gets to about 5-10 mph
    Thought about the music but I would rather not end up like some LT guys that the spindle and hub completely detach from the LCA lol
  13. May 26, 2018 at 10:39 AM
    timbaland1311
    timbaland1311 Active Member
    Tim
    Nantucket
    Tacoma
    2009 white Tacoma TRD with 3" OME lift kit, 855 coils, and dakar springs, total chaos UCA's, Nurf steps, 50" Led upper windshield mount radial light bar, 17inch SCS Ray 10 matte black, Cooper STT PRO 285/70/17, blacked out badges, tinted.
    hey did you ever figure out the issue i think i may have the same thing happening to me its a squeaking that gets faster with acceleration only thing is it sounds like its in the front tho,
