Whining bearing noise from pulleys
Discussion in '1st Gen. Tacomas (1995-2004)' started by echo8287, Jun 1, 2022.
  1. Jul 8, 2022 at 11:55 AM
    LearningToFly
    LearningToFly Well-Known Member
    Northeast Alabama
    2004 Double Cab
    Let us know if that fixes you up. Mine was making a low moaning sound. It sounded exactly like a power steering pump low on fluid. It wound up being my alternator. I don’t think it was the bearing in the alternator though. Just unplugging the alternator eliminated the sound. I just swapped it out for a new one.
  2. Jul 8, 2022 at 8:13 PM
    echo8287
    echo8287 [OP] Active Member
    David
    Ga.
    99 prerunner
    The free bearing are not the alternator bearing sorry, they are for the lower idler belt tension pulley. those are the extra ones I bought. If you would like one of those they are the ones I have available.
  3. Jul 9, 2022 at 12:45 PM
    mbeers6
    mbeers6 Well-Known Member
    East bay, ca
    03 tacoma double cab 4wd
    Air filter
    LOL, misread your message. Okay I've replaced my idler bearing so no need there, I'm sure someone else will take you up on it!
  4. Jul 10, 2022 at 12:56 AM
    echo8287
    David
    Ga.
    99 prerunner
    Road tested and after the lower idler bearing was changed, oddly the noise level was lowered but it is still there. I have the alternator bearings now and am going to to replace them next. I was having to listen a little harder to hear the noise. That bearing might have been contributing some whine as it had a little play in it when I removed it. Maybe after 240,000 miles several components are worn out. I will post again after the alternator bearings are changed. Hey,"learning to fly" that is what is sounds like, low moaning sound, even lower since I changed the idler bearing. In the beginning I thought it was the power steering pump but with the stethoscope it sounded like the alternator.
  5. Jul 10, 2022 at 2:58 AM
    LearningToFly
    Northeast Alabama
    2004 Double Cab
    Did you try unplugging the alternator and running it temporarily?
  6. Jul 10, 2022 at 7:33 PM
    echo8287
    David
    Ga.
    99 prerunner
    I'll try unplugging the alternator tomorrow. I was going to change the bearings out tomorrow so I will do as you said first before I take it off and apart.
  7. Jul 27, 2022 at 7:53 AM
    echo8287
    David
    Ga.
    99 prerunner
    Changed the alternator bearings out and the brush assembly>still no joy. Changing and cleaning the power steering fluid today, will see if that makes any difference.
  8. Jul 27, 2022 at 10:00 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I found this video very helpfull when I did my power steering.
    leid likes this.
  9. Jul 27, 2022 at 10:36 AM
    leid
    leid Well-Known Member
    Brandon, MS
    1997 V6 Tacoma 4x4 & 2020 V6 Tacoma TRD 4x4
    ECGS & ZUK diffs w lockers/Marlin R150F/NITRO axles/winches
    Good call! A clogged reservoir screen can starve the pump causing it to squeal. That video is an excellent guide on cleaning it up. And the "light" check on the reservoir screen will demonstrate the effectiveness of the procedure.
    Digiratus[QUOTED] likes this.
