Whining noise as I turn steering wheel to the left.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco99sr5, Aug 4, 2021.
  1. Aug 4, 2021 at 3:42 PM
    Taco99sr5
    Taco99sr5 [OP] Well-Known Member
    1998 Tacoma 4x4
    Hi everyone, I notice that every time I turn my steering wheel to the left there’s a whining sound that stays around for a bit even once driving down the roaD. It only happened when I take wide left turns and it lingers for a bit then goes away.
  2. Aug 4, 2021 at 6:52 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Sounds like possibly a wheel bearing failing, raise the front wheels off the ground and check for play or noise when you spin them.
  3. Aug 5, 2021 at 8:02 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    I'll second the wheel bearing. Although, after several attempts to prove to myself that it was the wheel bearing (and justify the cost of replacement) I couldn't hear any noise from spinning the wheel, nor could I notice any play in the wheel if I tried to move it around. I eventually ruled out a list of other things, and finally replaced the front bearings... and my suspected bearing issue disappeared.
  4. Aug 5, 2021 at 8:06 AM
    Taco99sr5
    1998 Tacoma 4x4
    Doesn’t sound like a wheel bearing failing it’s more of a noise that starts once I fully turn the wheel to the left.
  5. Aug 5, 2021 at 8:07 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Have you checked your power steering fluid level?
  6. Aug 5, 2021 at 8:23 AM
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    Well thats good to know.... just went through replacing almost everything on the front end of my truck and the noise hasnt left. But theres no play and the wheels spin like a top when i jack the truck up so maybe ill just ride with it for a while lol
  7. Aug 5, 2021 at 8:56 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    I'd just replace them and cross 'em off the list. Pull the spindles and take 'em somewhere if you don't have a press. Parts are like around $200-250, shop charge can range from $160-250... If you let a shop do the whole job, it'll be $1000-$1400.
