Whining noise at 2200+ rpms
Discussion in '1st Gen. Tacomas (1995-2004)' started by BajaBound, Mar 14, 2016.
  1. Mar 14, 2016 at 11:14 PM
    BajaBound
    BajaBound [OP] Member
    01 Tacoma
    Supercharger, Fox Suspension, ARB front bumper
    Hi all,
    I have an 01, 3.4L, 5 speed Tacoma with a 2nd gen. supercharger. A few days ago it started making a pretty loud whining noise starting around 2200+ rpms all the way until I shift gears. Once I shift it sounds fine until I get into those higher rpms again, and so on. A friend noticed the center bearing needs to be replaced but I'm pretty sure that that's a different issue. Anyone have an idea of what could be causing this alien-like whine? Thanks for the help.
  2. Mar 14, 2016 at 11:17 PM
    nickj604
    nickj604 Well-Known Member
    Nick
    Vancouver BC
    2019 RAM 1500
    To be announced
    Sounds like a bearing. I'd listen to your friend,think about it its spinning so is the bearing the faster you go the louder the whine gets .... 1+1=2
  3. Mar 14, 2016 at 11:25 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
  4. Mar 15, 2016 at 4:44 PM
    BajaBound
    01 Tacoma
    Light came on and the code that came up was for a knock sensor in bank 2. I've read lots of mixed things about knock sensor codes so don't know what to think. I don't have the time nor the know-how regarding a knock sensor so it looks like time to drop it off and get bent over. Thanks for the help
