Whining Noise - Brakes?
Discussion in '1st Gen. Tacomas (1995-2004)' started by scaliusmaximus, May 13, 2024.
  1. May 13, 2024 at 2:18 PM
    scaliusmaximus
    scaliusmaximus [OP] Well-Known Member
    pascal
    Los Angeles
    2001 Tacoma Prerunner XtraCab 3.4l
    none
    Whining noise associated with brakes. It goes away once i brake or when I accelerate. I only hear it when coasting or for a short time when the truck is in park with the brake pedal released.
    I wonder if there’s a leak in the vacuum line from the manifold to the booster which would explain the noise going away when braking and when accelerating right?
    Any advice appreciated
  2. May 13, 2024 at 4:08 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Rotational squeak?
  3. May 13, 2024 at 5:59 PM
    scaliusmaximus
    pascal
    Los Angeles
    none
    Maybe, but idk if that also covers the whining noise that lasts for a few seconds while it’s stopped and put in park.
  4. May 13, 2024 at 6:51 PM
    ControlCar
    Steven
    Sugar Land TX
    Can you replicate the squeak when stopped by reving engine?
  5. May 14, 2024 at 10:45 AM
    scaliusmaximus
    pascal
    Los Angeles
    none
    Whining noise goes away when accelerating in motion. The noise lasts a few seconds with engine off and car in park with no pressure on brake pedal.
  6. May 14, 2024 at 11:35 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Whistling sounds are generally associated with a failed brake booster or vacuum leak. Whining, would imply a bearing or pully complaining.
    However if the noise persists when the truck is off, probably a brake booster.
