whining noise in engine compartment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gano4taco, Mar 25, 2021.
  1. Mar 25, 2021 at 1:49 PM
    Gano4taco
    Gano4taco [OP] New Member
    2007 White Tacoma Prerunner V6
    2007 6 cylinder.
    In low rpms there is a whining noise and the truck seems sluggish. I changed the waterpump, serpentine belt and had the transmission flushed with BG additive. Any suggestions. I have 236K miles.
    Thanks
  2. Mar 27, 2021 at 8:09 AM
    topoutman
    topoutman Well-Known Member
    Ellensburg, WA
    2013 DCLB 4X4 TRD SPORT
    Did you check your idler’s when you replaced your belt? Common problem, not sure if it will make your truck sluggish but it will make a whining noise or rattle. Alternator?
    Dm93 likes this.
  3. Mar 27, 2021 at 11:06 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    After all the idlers (3) and tensioner (and alternator) there is the PS pump and AC compressor to check.
    Then front wheel bearings, driveshaft/coupler freezing/failing, and then throttle body/MAF dirty for power.
    Vacuum lines rotting out also. Good hunting.
  4. Mar 28, 2021 at 12:46 AM
    TacoTuesday1
    FL
    I've heard many noises from vehicles (not necessarily Tacoma)
    such as clicking
    which is usually a worn CV joint
    last time I heard what would be described as whine,
    was a failing power steering pump
    DG92071 likes this.
