Whining noise in neutral!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Killer Red Taco, Jun 3, 2009.
  1. Jun 3, 2009 at 10:34 AM
    Killer Red Taco
    Killer Red Taco [OP] NorCal Rock Whore
    Whatsurname
    BFE–Norcal
    007 Tacoma A/C TRD O/R Impulse Red 4x4
    Bilstein 5100 on front at 1.75 setting • 5100 on back• K&N Air Filter• TRD Seat Covers• Day Time Running Lights• Foglights Anytime• Hella 500 lights in grille• Rear TSB Springs• Alternative Locker Mod• CB and 4 ft firestick II• Billet Grille• Kid puke in the back!• 265/75R16 Goodyear MT/R• 16" Devino wheels• Hose Clamp Mod• Revenge Fab Sliders• No Sway Bar• A Hottie as Copilot
    My truck has whined in neutral for a while now, but today is got worse. It got super loud. I put the truck in drive then back to neutral again and it stop. I am not sure if all the tacomas whine or is it just mine?
  2. Jun 3, 2009 at 10:35 AM
    allupinsydeyou
    allupinsydeyou Well-Known Member
    so cal / vegas
    v8 swapped yota. dyno tuned @ 400hp
    modified total chaos uppers and lowers... king coilovers, deaver leafs, full cage, 351w motor swap, etc..
    self installing super charger :)
  3. Jun 3, 2009 at 10:37 AM
    Killer Red Taco
    Whatsurname
    BFE–Norcal
    I wish I opened the hood one day and *BAM* supercharger
  4. Jun 3, 2009 at 10:38 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  5. Jun 3, 2009 at 10:39 AM
    allupinsydeyou
    so cal / vegas
    hahahah im tellin ya man... its just hidden.. check behind the flux capasitor. its there. :D
    but really... your a manual or auto? i will take it auto since you said put it in drive. whats your fluid level at in the tranny?
  6. Jun 3, 2009 at 10:41 AM
    Killer Red Taco
    Whatsurname
    BFE–Norcal
    Auto and we have sealed trannys :annoyed:
  7. Jun 3, 2009 at 10:42 AM
    Killer Red Taco
    Whatsurname
    BFE–Norcal
  8. Jun 3, 2009 at 10:44 AM
    allupinsydeyou
    so cal / vegas
    hahaha fuck... i keep forgetting about those new sealed mofo's. awesome idea, bad on practicality. take it to toyota and ask them if they can hit it with the scan gauge and see if it is low. notice any leaks from the trans anywhere? any small drips under the trans after being parked for a while?
  9. Jun 3, 2009 at 10:45 AM
    Killer Red Taco
    Whatsurname
    BFE–Norcal
    I have not seen any leaks and I have looked, I have been all over the pig looking for leaks and at the frame.
  10. Jun 3, 2009 at 10:47 AM
    allupinsydeyou
    so cal / vegas
    you ever try to shift the truck like it has a manual valve body in it?
    (meaning shifting from first to second and second to third... but doing it while the truck is like floored.)
  11. Jun 3, 2009 at 10:55 AM
    Killer Red Taco
    Whatsurname
    BFE–Norcal
    No so much, I run it in 1st and 2nd alot when I climbing and going down hills. But I haven't shifted like I was racing it.
  12. Jun 3, 2009 at 11:05 AM
    allupinsydeyou
    so cal / vegas
    ah well... it could be a stretched band in the trans. you noticing any late shifts? or does it kick any harder when it shifts?
  13. Jun 3, 2009 at 11:07 AM
    Killer Red Taco
    Whatsurname
    BFE–Norcal
    Seems to shift fine, also i forgot I have less than 30,000 on it.
  14. Jun 3, 2009 at 11:16 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Missed the auto part, my bad. sounds like warranty item
  15. Jun 3, 2009 at 11:20 AM
    allupinsydeyou
    so cal / vegas
    yep. take it in and let toyota deal with it if you have less than 30k on it. that isnt that old to already be having troubles with it.
  16. Jun 3, 2009 at 11:21 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    especially since you can't even check the damn fluid level.
  17. Jun 3, 2009 at 11:24 AM
    allupinsydeyou
    so cal / vegas
    hahahaha. once again... a idea that looked awesome on paper... not so much in practical application. but hey... its making it so they can only be serviced by toyota... revenue my friend.
