Whining noise in rear
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sniper55, Nov 26, 2017.
  1. Nov 26, 2017 at 3:38 PM
    Sniper55
    Sniper55 [OP] Active Member
    2016 tacoma
    I am noticing a whining noise in the rear. It almost sounds like tire noise. Toyota service tec said Tacoma 's its normal for Tacoma 's. Does anyone have similar issues.
  2. Nov 26, 2017 at 3:43 PM
    LDL
    LDL Well-Known Member
    San Diego, CA
    2017 Tacoma 4x4 DCSB
    Air conditioning, floor mats, seat belts
    Hmm... I only heard a whining noise when my ex gf was in the truck.
    JS760, vuTron, 2016Tacoman and 4 others like this.
  3. Nov 26, 2017 at 4:56 PM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
  4. Nov 26, 2017 at 5:32 PM
    AFMurse2014
    AFMurse2014 Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    It's the rear diff... My truck does it too. There was a recall for them leaking, but it is very annoying
  5. Nov 26, 2017 at 6:35 PM
    bluenv
    bluenv Well-Known Member
    AeroCooper likes this.
  6. Nov 26, 2017 at 6:54 PM
    ShirtTucker
    2017 V6 Sport AC MT
    Lots-o-stuff
    I hear ya. I've spent the last few hours scouring the web about the problem. It has been a problem for Toyota for a LONG time. They should have figured out a solution by now. Take a look at this:
    http://media.fixed-ops.com/Toy_ServiceBulletins/sb0057t13.pdf
    Someone on this forum suggested taking the truck in to a diff. specialist, saying that they could probably fix the issue for about $500. If mine gets too bad, I might just bypass Toyota and go that route. I have very little patience for getting the runaround.
    Joe23 likes this.
  7. Nov 26, 2017 at 8:43 PM
    bluenv
    Thanks for the link. My 05 is a manual, so I was missed that treat on the 2nd gen. It's clearly an ongoing problem that Toyota doesn't want to address. Maybe people will have to organize a class action like they did for the 2nd gen frames. There are a couple of used Tacomas on the local lot. I might test drive them and see if they howl. I'd like to hear it BEFORE I buy my truck, not a couple of months later.
  8. Nov 26, 2017 at 10:46 PM
    Stuffs
    Stuffs Active Member
    Test drove the 2018, TRD OR.... sorry to report its the same rear diff, same howl at 65mph...
    Berto likes this.
  9. Nov 26, 2017 at 11:58 PM
    bacon_st
    bacon_st Well-Known Member
    San Diego
    16' Taco TRD sport
    As someone else mentioned already, it's the rear diff. I had the same issue, and my truck ended up getting seized up and broke down on the freeway. Thankfully this was before the rear diff recall, and there were enough diff's to go around. My warranty took care of it, and I got a new diff and axle gears, but they kept the truck for a little over a month. Of-course, everything is normal to the service techs.
  10. Nov 27, 2017 at 2:43 AM
    dsixnero
    dsixnero Well-Known Member
    Dan
    2016 Tacoma TRD Off Road White
    None yet
    I was told , it's normal tire noise, and it sounds like bad tires and has since it was new. It's not a howling, it's more like chopped tires from bad shocks. Tire rotation does not change this. 16 TRD OR AC
  11. Nov 27, 2017 at 4:05 AM
    rdjr17
    rdjr17 Well-Known Member
    Ron
    Nepa
    2019 voodoo blue Trd pro
    Mine was fine till I hit 6,000 miles no leaks , but noise is getting louder , report it so it documented then when rear fails you got paperwork to fall back on . .. it's a know problem and if they replaced frames on trucks in the past im sure switching rears will happen when they find the solution
  12. Nov 27, 2017 at 4:10 AM
    Clearwater Bill
    Billy
    Largo Florida
    Yes, lots and lots as you can tell by the responses.
    But most owners never hear it. Because windows up and music on tend to drown it out.
  13. Nov 27, 2017 at 8:32 AM
    bluenv
    At least it did it on the test drive. Most report it takes months to show up. I'm sorry to hear it was on an OR. That's the model I would want.
  14. Nov 27, 2017 at 12:29 PM
    Berto
    Berto Braaaptist
    Berto
    Michigan
    '17 Inferno TRD 4x4 OR
    Well this is not reassuring Toyota... very disappointed to read this. Wonder if a regear would help, if so, which way to go? Mine will be loud some days, barely noticeable or gone at all the next... I also know where it does it, so I avoid those speeds... frustrating, but also don't want to take a hit on the truck... My 2 cents, look to fix it locally if you can afford it.
