Whining Noise when Turning Wheel at low Speeds
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hacksaw34, Aug 7, 2015.
  1. Aug 7, 2015 at 9:24 AM
    Hacksaw34
    Hacksaw34 [OP] Member
    Dtc
    2000 Tacoma 4wd
    Sometimes on my 2000 Tacoma I hear a slight whining noise at low speeds when turning the wheel sharply. Is this an indication that the power steering pump is starting to fail?
  2. Aug 7, 2015 at 9:27 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Don't turn the wheel sharply.
  3. Aug 7, 2015 at 9:29 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    if the fluid level is ok, then drain it and clean the screen in the bottom of the fluid reservoir then put new fluid.
    very often the whining is from a clogged up screen because of old worn out fluid
