Whining noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cloudbnd, Mar 19, 2022.
  1. Mar 19, 2022 at 7:27 AM
    cloudbnd
    cloudbnd [OP] Well-Known Member
    Randy
    2008 silver DCSB 4X4 OFFROAD
    I have a 2008 DCSB offroad 4x4. I have been hearing a periodic whining from the drivers side. It will sometimes start as I sit at a stoplight and I can hear it start up as I am driving down the road. Any suggestions what might be the cause. Heater/AC fan is off
  2. Mar 19, 2022 at 9:19 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    2015 Toyota Sienna with rear locker
    Do you have the radio on? Does it sound like it’s coming from the speaker next to you? Could be a ground issue.
  3. Mar 19, 2022 at 9:33 AM
    cloudbnd
    Randy
    Radio was off. The bed outlet doesn't work due to the previous owner installing a remote start. The Toyota tech said something about a grey wire spliced in(I thought it was the switch). I think I will have my mechanic remove the remote start.
  4. Mar 19, 2022 at 9:45 AM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
    Alternator bearings going out?
  5. Mar 19, 2022 at 10:01 AM
    cloudbnd
    Randy
    Is there a way I could check that out? Thanks for the help.
  6. Mar 19, 2022 at 10:01 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Check your power steering fluid level, beyond that it's anyone's guess without hearing it.
    Most likely it would be low power steering fluid or something on the belt drive (idler/tensioner pulley, alternator, water pump, etc) but ultimately you will have to pinpoint the source or take it to someone who can.
    A mechanics stethoscope, sawed off broom handle or long screwdriver can help pinpoint noises just be careful poking around moving parts.
  7. Mar 19, 2022 at 10:05 AM
    cloudbnd
    Randy
    Yeah I don't want a broom handle rammed in my ear. I don't hear it in the engine compartment as much as in the cab. Thanks alot for the input.
  8. Mar 19, 2022 at 3:18 PM
    ZMan2k2
    Richard
    Under a tinfoil hat
    @cloudbnd In the cab, but not out? Could be the same sound I’m hearing from my fan motor. When cold especially, it’s a whining noise coming from there. Does it go away shutting the fan off?
  9. Mar 19, 2022 at 5:02 PM
    cloudbnd
    Randy
    I have the fan off and radio off. Sounds like a faint crotch rocket in first gear
  10. Mar 19, 2022 at 5:06 PM
    ZMan2k2
    Richard
    Under a tinfoil hat
    If it increases with the trans, I’d say ground loop.
    wi_taco likes this.
  11. Mar 19, 2022 at 5:56 PM
    wi_taco
    Adam
    This is exactly why I asked about the radio. Certainly can be present without it, but often noticeable through the speakers too (at least the ones I've seen).
